2007 S65 with 53K miles, Transmission not shifting
My S65 Tranny no longer shifting. It had squealing noise prior to going into Neutral.
I removed the Valve body completely cleaned it out, removed upper, lower, checked all the solenoids and they are good.
The Y3/6Y2 (Shift Pressure Regulating Solenoid) pressure goes upto 9999mbar as soon as I put into gear and press gas pedal. This Solenoid is actuated based on Torque input and applies the clutch. I am assuming my transmission is shot. Is there anything else I can look into prior to changing it out?
