S55 AMG - intermittent no start
Old Jan 17, 2024 | 09:00 AM
FL_S55AMG's Avatar
2004 S55 AMG
So things have been going great with the car, but lately I get in it after I’ve driven it, it won’t start….it won’t crank over. But after 1-3 key cycling times it fires up fine. All the lights come on there’s no check engine lights or any beeps or issues, it just doesn’t start - doesn’t crank. seems to only be doing it when it’s warm. So I’ve done some researching on here and it seems like there are a few things. First the crankshaft positions sensor. Mines been replaced already. It’s only 30 days old. The next step I think is the fuel pump. So I’m testing that to see if it works. I’ll update this thread, but any other suggestions please post up. Thank you.
Old Jan 17, 2024 | 09:12 AM
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
Does the battery sit on a tender? Is the battery healthy? You have the main 2 culprits but I can see a weak battery causing random issues. Good news is if it’s the fuel pumps it’ll degrade to where the problem is easily diagnosed. I had extended cranking, threw a CPS at it to no avail, maybe a year or 2 later, the fuel pumps showed themselves. No problem since. But I think you’ve read that somewhere already.
maw
Old Jan 17, 2024 | 11:06 AM
S_Holford's Avatar
2003 S55 AMG, 2005 C320 Coupe, 2020 Jeep Gladiator Mojave
The crank sensor should be a first-up maintenance item on any M113/M113k engine if you don't know the maintenance history....in my opinion anyway. It's cheap and relatively easy to change.
If you aren't aware of this, you can access a diagnostic menu from your climate controls to view your battery voltage. I watched the death of my alternator by doing this. This is how to do it:
Old Jan 19, 2024 | 05:09 PM
FL_S55AMG's Avatar
2004 S55 AMG
Awesome...good suggestions guys. All checked out fine....issue is ignition switch it looks like ill have to see if it can be rebuilt....1st up is search here...
Old Jan 19, 2024 | 05:10 PM
FL_S55AMG's Avatar
2004 S55 AMG
maw
No to battery tender - I drive it daily - and voltage is fine.
Old Jan 19, 2024 | 09:21 PM
maw1124's Avatar
Yeah, that's in line with the symptoms you described. I've never had that issue. Please keep us advised of how you solve it.
GL,
maw
Old Jan 22, 2024 | 09:26 AM
FL_S55AMG's Avatar
2004 S55 AMG
OK - so we have diagnosed it as the EIS - Electronic Ignition Switch - all roads lead to that, and i am taking it out today. Found this company that rebuilds or replaces them....costly, but I think it is worth it because there is no alternative. It would just keep getting progressively worse and leave me stranded somewhere I am sure. Aparetnly, there is also a way to fix it if you are good at soldering, if of course the issue is the little module inside...see the youtube video below.
https://mbzexperts.com/product/merce...ice-w220-w215/
Old Jan 22, 2024 | 09:55 AM
maw1124's Avatar
Those folks don't seem to support the S55. These guys might ... https://www.lacartech.com/products/w...31269996003422
GL
maw
Old Jan 22, 2024 | 06:00 PM
FL_S55AMG's Avatar
2004 S55 AMG
Yep - they support all W220 .... had to give them the VIN for it and it was fine. They dont support the S55AMG for anything else though.
Old Jan 29, 2024 | 03:13 AM
ChampagneC's Avatar
Please keep us posted on this. When I read your first post I thought EIS
Had it go on my clk and just sold it as it was an extra car we didn’t need
if EIS goes on my S55 I’d love to know a shop that can do the rebuild
Old Feb 2, 2024 | 09:21 AM
FL_S55AMG's Avatar
2004 S55 AMG
Yep - it is expensive - i can tell you that they do NOT rebuild the EIS for 2004 vehicles, it is VIN# specific....apparently Motorola produced a number of variants (4 exactly) over the period the S55 was produced, and only one of those variants can be rebuilt....rebuild is approx $500 cheaper. I did have a 2nd key coded and supplied...all in for a NEW EIS and coding and second key was $1,500. But it is in, and works wonderfully at this point - no issues....both keys work.
