2009 S63
Old Oct 15, 2024 | 11:26 AM
Shadow 6.3's Avatar
2009 S63
2009 S63
Good morning. I need your help.
​​​My ​ car is very sluggish from the start....until I get going. RPMs are up...before shifting gears.
What could the issue be?
Old Oct 15, 2024 | 12:09 PM
jimyj's Avatar
E320
Based on my years of experience, it sounds like your transmission might not be engaging correctly or there might be an issue with the torque converter causing the sluggish start. High RPMs before shifting can often indicate problems with the transmission fluid, perhaps due to being low, old, or contaminated. Another unlikely but possible cause might be the intake air system—if there’s a block or a sensor fault, it could cause poor throttle response, contributing to sluggishness. I’d also check if your Mass Air Flow (MAF) sensor is dirty or faulty, as this can affect engine performance and shifting readiness. For accurate diagnostics, you should pull codes from the Transmission Control Module and the Engine Control Module. The logic within these modules will likely provide insights into what might be going awry. A full system scanner like the youcanic will access all modules within your vehicle, giving comprehensive data coverage, especially for complex systems in the S63. Relying on a basic scanner like the BlueDriver, which primarily focuses on engine codes, might leave you without the full picture. Have you checked the transmission fluid level and condition recently? It might be worth ensuring it’s topped off and looking good.
Old Oct 15, 2024 | 01:41 PM
Shadow 6.3's Avatar
2009 S63
Thanks.
