03 S55 m113k stumbles idle & partial throttle
My only suggestion is to hook it up to a really good scanner, like an AUTEL that will read every single code and module and see what comes back. Just because its not throwing a check engine light doesn't mean it won't tell you that something else is going on causing the issue. For example, My "Unmetered air" issue, is being resolved by the computer automatically adjusting AFR, and it only happens for a split second.
The last suggestion i could give to completely rule out a Vac leak anywhere in the system is to go out and buy an automotive smoke machine. That will give you your answer and you can cross it off the white board.
- Joe
- Joe
The other thing I'm knocking up against is all of the O-Rings and rubber at the back of the supercharger are probably due by now as well. We were chasing a CEL on mine which turned out to be a fuse related to the SAI pump. But along the way, spraying brake cleaner at the rear driver side of the intake we noticed her stumble a bit, which meant what we were spraying was getting where it shouldn't. So next oil change every rubber gasket and O-ring at the rear of the intake is getting changed. 20years living at the back of this hot engine sandwiched against the firewall on long 20+ hour freeway runs, yeah they're done.
CEL is gone and no stumble, but that just means any air leakage is within spec where the ECU can adjust the A:F ratio. That doesn't mean the rubber shouldn't be replaced. And I'm still seeing 21mph on highway runs over 80mph.
Point is, these aren't "break fix" cars. If you're seeing ill effects, you're already late. Download the maintenance schedule, catch up and stay caught up. Otherwise you're chasing ghosts.
maw
maw
That metallic sound near the rear of Bank 1 is what's concerning me, but I'd like to see a smoke test done first. If there's some hose missing, that would let you hear engine internals when you shouldn't.
Keep us posted.
maw
Keep us posted.
maw
P202a-001- fuel pump relay positive short
P202a-002- fuel pump relay short to ground
P202a-008- fuel pump relay operational problem
b1416- coolant circulation pump short or positive overload
B1634- hcs pump short to ground
Attached are pictures of the scan session . My buddy says the scanner some times provides junk codes but this is what I got from the other scan session despite no actual check engine light which I know works because it came on when I missed that vacuum line falling out of the back of the supercharger and started the car up and ran it. If these are accurate, they seem like pretty significant codes and the check engine light should come on yet it's not coming on. When I search the p202 codes on the forum they point to idle speed control 🙄 that thread focused on a guy grinding his TB shaft and having to replace TB with stock unit
I examined it further and can feel the butterfly flap is loose despite the 2 screws in the shaft being tight . Do I simply look to replace the butterfly plates ? Is there an easy free fix for this or am I DOA and have to replace the entire unit 🤔
And you probably need a new throttle body as well. Not surprising, especially if the car was once tuned, as most of them have been at this point.
Guessing from a long way away, you might have bought one that was tuned, ridden hard, put up wet, then "put back stock" for sale.
I'd clear those codes, get the car on a battery tender to full charge, then re-scan and see what comes back. But if throttle body and some misc gaskets and O-Rings are all the car needs, consider yourself lucky. Buy a used TB off ebay, new OE gaskets and O-Rings and have a nice day.
Welcome to the game.
maw
PS... for what I've prescribed above, I wouldn't even bother to DIY it. A qualified indy will have that done in a few hours for way less grey matter than you're ever going to spend on it. Also if I was going to do that, I'd do the EGR valves too. If I can find an ebay link I'll come back and post it. Here you go... these... https://www.ebay.com/itm/11663188445...IAAOSwi-tjfQkX ... and this... https://www.ebay.com/itm/11654596473...0AAOSwx35n7k7M ... so for $500 in parts and a few hours of work by someone who knows what they're doing your problems could all be solved... if you never drive the car as it was engineered, why bother??
maw
PS... for what I've prescribed above, I wouldn't even bother to DIY it. A qualified indy will have that done in a few hours for way less grey matter than you're ever going to spend on it. Also if I was going to do that, I'd do the EGR valves too. If I can find an ebay link I'll come back and post it. Here you go... these... https://www.ebay.com/itm/116631884459?fits=Year%3A2006%7CModel%3AS55+AMG&_s kw=w220+s55+egr+2006+oem&itmmeta=01JXBM5113B0JRETK MQKE5RKSF&hash=item1b27cd52ab:g
Fine, do the work yourself. Just buy all the OE seals, gaskets and o-rings where you see smoke. Yes I said and mean all.
That with the throttle body might just get you where you need to be. Fuel filter is table stakes for these by now (I'm on my 4th... change them damned near like cabin filters).
Start there, report back. For your skill set, this is all simple. When you reconnect the battery all systems might be go.
maw
maw
I might just pull and clean . I've not gotten any codes pointing towards the system having an issue but understand the build up will cause issues . My throttle body is in the mail so I plan to replace the map sensor , breather hose Union and surge tank gaskets along with any gaskets related to the TB . I'm trying to locate that rubber grommet for the metal Evap vacuum line that runs into the back of the supercharger. And if i can't find it or a viable option as a replacement it's going to get sealed into place with silicone along with the metal line .
maw
PS... as tempting as it might me, for whatever reason I don't know, these cars don't need a lot of re-engineering. Find the offending part, replace it with a new (or used if unavailable) factory part and move on, is almost always the best course of action. Anything else tends to be asking for varying amounts of trouble for almost no benefit, I've observed over the years. That's why they're Mercedes Benzes. No need to recreate that wheel and no benefit from doing so as a general matter.
maw
