2015 command internet
You start by connecting the phone by dedicated bluetooth to the car.
Go to worldO then pull back dial, go to Settings, check the Wifi Sharing box.
There may be some key code to copy or not. The phone will show the MBxxx name on the wifi connection when it is in the car. and go to back to others when the car is turned off. It has to show the MB on the wifi connection.
THIS will cause the internet to connect, MB Plus and get the MB apps It hesitates some times. And is slow to load and start at some times. It seems to connect well when you have a strong +5 bar phone signal. But stays on after the signal weakens.
Then to get wifi hot spot go to VEHICLE then pull down to System Settings, then go to Easy connect with key (something like that, its too convoluted to remember That's why MB is a pain in the as)
And it gives you a code key to put on your phone during the process. Go to your phone settings, and Connections, and there will be a mobile hotspot or tethering choice, and you will enter the code key at that point between the 2.
Then the mobile hotspot will appear when you want to accurate it.
Mbrace or MB dealer do not know how to make this work. They claim the 15, 16 are too old and it wont work on anything under 17.
Tha dealer says all the newer 17 up cars work alot better, and they didnt give any complaints. I don't know if they are using the search.
