S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
ABC Suspension Wheel and Tyre easily lift
Old Aug 15, 2021 | 03:52 PM
Bilbo7's Avatar
2015 SL63 AMG (R231)
Hi All
I have just joined
I bought a rather nice in appearance SL63 from a MB dealer at distance but did go there and give it a short test run
It seemed fine
On arrival by trailer it had a not related to this problem and went into the local MB dealership and they also found a leaking rear ABC Shock
That they replaced under warranty as was the other work but afterwards the suspension was banging at the back on the other side they had it back but said nothing wrong
Far from helpful.............. whereas the seller dealership say they will pay to fix anything found wrong down here
So I took it to an independent a fair way away from me for an inspection really just as the MB seller was 200 miles away
The independent pointed out to me the other rear wheel, when up on a X ramp with wheels dangling, pushes up easily and let me try and its simply put your finger tips up and it moves SO effortlessly
The new ABC shock side will not move at all
However, when I asked why they say its worn but will not comment more or what is worn nor do they wish to be involved in against BM claim
I do not have any problem with that attitude and they thought unless it actually leaked a Warranty would not cover a replacement cost
Its going back to the selling dealership to sort that and another problem that the MB dealership near me did not sort out
So what would you all think is the ABC problem given the pressures in a ABC system it seems illogical to easily move any wheel
This has been going on for weeks especially as the ABC shock that was replaced came from Germany and it takes 5-10 days and the first to arrive was the wrong part near a month slowly passes...............
So it’s been here over 5 weeks now and only to and from the garage but for an odd initial drive out or testing now I will not drive it as the front is going light on a not fast bend.......... if it was the rear that would just be FUN grin
I would like opinions before getting the sellers response
Old Aug 19, 2021 | 09:42 AM
Bilbo7's Avatar
Hi I have just realised this is on the wrong forum and have moved it to SL63
Sorry
