S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
Soft Close + Auto Window Problem
Old Mar 15, 2023 | 08:35 AM
S63C4's Avatar
2016 S63C4, 2021 Escalade Sport Platinum, 2023 Polaris Slingshot R
Angry Soft Close + Auto Window Problem
Hey guys,
Recently my coupe's passenger door soft close stopped working and the windows don't seal when the door closes. Upon opening the door, the windows go a 1/2" down as normal, but not up when the door gets shut. Then, if I hold the window button up 1/10 of a second too long, they open a 1/2" again! As you can imagine, this is driving me nuts!
It seems like some kind of logic error, not a mechanical failure, or could be a combination of both. Anyone had this happen before?
Old Mar 15, 2023 | 10:18 AM
haa's Avatar
haa
Originally Posted by S63C4
Hey guys,
You probably need to reset the limits. Open the window and hold the window opening button for 10 secs after the window is fully open then close the window and hold the window closing button for 10 secs with it fully closed. That shoudl fix it
Old Mar 16, 2023 | 08:00 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
could be the micro switch that activates the glass and door
My soft close quit and I started to tear it apart or take it to the dealer to figure it out. but after a month, it started working again.
Old Mar 17, 2023 | 01:20 PM
S63C4's Avatar
Wink
The reset procedure worked, but I don't know exactly what the actual procedure is. It took me around 4-5 minutes of playing with both windows to finally get all 5 automated actions functioning normally.
Thanks very much for the clue. I thought of a limit reset, didn't know the procedure and dismissed the idea because I convinced myself it wouldn't fix the soft close. Anyway, all's well that ends well.
Old Mar 17, 2023 | 02:57 PM
konigstiger's Avatar
'71 Pinto
Old Mar 17, 2023 | 03:17 PM
S63C4's Avatar
Thanks for the procedure. I'm not sure it's that simple because until I started messing with the back window, then the front again, then the back again and on and on, somehow it eventually reset. Hopefully this archive will be completely useless. LOL.
