S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
S63 engine shutters
Old Jul 11, 2016 | 08:28 PM
1BLKAMG63's Avatar
2011 Mercedes S63 AMG
S63 engine shutters
OK I hope I don't have to post too much more on the site. I am noticing when I apply the break at a stoplight or stop sign The engine has a tendency to shutter almost feels like it wants to die. I have no idea what it is. I was told it could possibly be bad fuel but I always run minimum 91 octane . Can't find 93. Recently I had the oil changed about three weeks ago. Not sure if that's why. I am showing zero codes. Even when I run my scanner on it. Still no hidden codes. 57k miles on a 2011 S63. Spark plugs need to be changed? Vaccum leak? Out dated database?
Old Jul 11, 2016 | 08:51 PM
PeterUbers's Avatar
Plugs and injectors is where I would start; what did the stealership recommend
Old Jul 11, 2016 | 09:20 PM
jenz's Avatar
S, GL
Plus check the right forum (think W221) for your model year, others may have similar issues
Old Jul 11, 2016 | 09:34 PM
PeterUbers's Avatar
Correct me if I'm wrong but your s63 had the first year of the m157 engine?
Old Jul 11, 2016 | 09:55 PM
1BLKAMG63's Avatar
I have not taken it in yet. Was trying to deter from doing that.
1BLKAMG63's Avatar
W221
Old Jul 11, 2016 | 10:04 PM
PeterUbers's Avatar
W221
Is that a yes?
Old Jul 11, 2016 | 10:13 PM
1BLKAMG63's Avatar
Is that a yes?
Yes it is a 221.
Old Jul 13, 2016 | 11:26 AM
1BLKAMG63's Avatar
Update on engine shutter.
Yes it is a 221.
I took my car in. The auto shop was able to scan my system and see that my #1 and 4 cylinder were misfiring. Enough to make the engine shutter here and there. But not enough to throw a code. Cylinder 1 misfired 56 times. #4 misfired 5 times. So I went to parts geek and ordered a few ignition could and new plugs. I'll be doing that next week to hopefully fix the issue on the shutter. I notice more lag on acceleration and shuttering at a stopped position. I will keep this thread updated as I progress. New plugs and cooks coming soon. Now I need to figure out the cylinder numbering.
Old Jul 13, 2016 | 02:06 PM
DC2016's Avatar
2008 s63 mercedes benz amg
Fuse for sunroof
Hi My 2008 S63 AMG My sun roof won't open, the shade opens but sun roof will not. Where can I find the fuse for the sun roof? And what fuse number?
Old Jul 27, 2016 | 08:12 PM
1BLKAMG63's Avatar
Engine shutter outcome S63.
OK. I changed out the plugs and the two ignition coil's. However after I replaced everything then number four was throwing a code for cylinder for misfire. So I had to take it into my local repair shop . After diagnosing the issue they found that the company sent me the wrong plugs . I was sent Bosch a radium . And I needed to order the genuine Mercedes Benz plugs. Now the tricky part is it is the same plug serial number and part number . However for the S 63 AMG It needs to not have a R in the numbering. What was happening is I had the incorrect resistance and it was causing the engine to misfire. New plugs to know ignition coil's and she is running great. So if you have a engine shutter or misfire check your ignition coil's and replace your plugs .
Old Jul 28, 2016 | 09:51 AM
Salo's Avatar
2012 E63 AMG
However for the S 63 AMG It needs to have an R in the numbering. What was happening is I had the incorrect resistance and it was causing the engine to misfire. New plugs to know ignition coil's and she is running great. So if you have a engine shutter or misfire check your ignition coil's and replace your plugs .
Do you mean ZR6SII3320 instead of Z6SII3320? My plugs from new are Z6SII3320 and so are the original replacements.
Old Jul 28, 2016 | 10:10 AM
Speedriven1's Avatar
Speedriven
MY2011 was the first year that the W221 had the Biturbo M157 engine. They had an issue with stumbling/stalling on many of the early Biturbos (S, E, etc.) which was more pronounced in the cars with stop-start. The dealer should have an update/re-flash that will fix the issue and, usually, help the transmission shift a bit more cleanly.
Next stop should be a trip to the dealer to see if you're on the latest firmware.
Old Jul 28, 2016 | 11:17 AM
1BLKAMG63's Avatar
Sorry. Correction. Z6SII3320 is the correct number. R is the incorrect Resistance.
Old Jul 28, 2016 | 11:19 AM
1BLKAMG63's Avatar
Appreciate this. they replaced the plugs to OEM plugs Z6SII3320 and it fixed the problem. its crazy to think such a powerful engine is fuel efficient stop-start. kind of a pain. but problem solved and shes back online. Bosch iridium's have the wrong resistance.
Old Jul 28, 2016 | 04:19 PM
1BLKAMG63's Avatar
I have the Bosch plugs if anyone wants to paypal me for them. they were in for about 1 hour. Bosch Iridium ZR6S113320. Message me.
