S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
AutoTalent | Renntech Ecu Upgrade + Exhaust + Spoiler for Mercedes-benz S 63 Amg B-T
Old Nov 8, 2019 | 02:27 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
Click HERE to order Performance Ecu+!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
Renntech Sound & Style Pkg
Click HERE to order Sound & Style Pkg!
RennTech is proud to introduce the all-new Sound + Styling Package exclusively for the W222 S63 AMG Sedan. With the release of the Sport Muffler and Decklid Spoiler, RennTech brings the perfect combination of styling and sound upgrade to one of Mercedes's most dynamic cars. This highly integrated pre-preg carbon fiber spoiler compliments the sophisticated and refined S-Class exterior design language. The spoiler is coated inside and out with an all new acrylic UV protection system. A second layer of UV protectant clear coating is also applied using traditional spray methods, in order to create a smooth and high gloss finish. This spoiler is designed to fit any S-Class Sedan model from 2016 and up. No drilling or modifications to the trunk are necessary, installs with 3M double-sided automotive tape. The RennTech Carbon Fiber Decklid Spoiler for the W222 S63 AMG Sedan is available in gloss and matte finish. In addition to the carbon fiber decklid spolier, this special package includes the RennTech T-304 stainless steel (SS) sport mufflers which are 100% hand made in the USA. This exhaust system is rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle. Our mufflers with 2 3/4 inch diameter tubing offer lighter weight than the stock exhaust and improve performance by reducing exhaust backpressure, increasing exhaust gas flow and cylinder scavenging. The RennTech Sport Muffler System for the W222 S63 AMG Sedan comes with an integrated valve system and utilizes the electronic OEM actuators. It is also available for vehicles without the optional electronic valve system. The system comes with all the required hardware.
Features
Improve performance by reducing exhaust backpressure
Increasing exhaust gas flow and cylinder scavenging
Stainless steel (SS) sport mufflers exhaust
The perfect combination of styling
Gloss and matte finish spoiler
Gain up to 10 HP & 15 TQ
100% carbon fiber spoiler
Sound upgrade
Renntech Hand-held Suspension Module
Click HERE to order Hand-held Suspension Module!
The RennTech Hand-Held Suspension Module (HSM) is designed to work with the W222 - S-Class Sedan, equipped with the Mercedes Airmatic and Magic Body Control Suspensions.The unit allows the user to have full control over all four corners of the vehicle’s suspension and adjust in 1mm increments. The HSM comes pre-loaded with a RennTech lowering setting. User can load their custom setting onto the HSM to set the vehicle to their preffered ride height. The desired lowering setting will be loaded onto the vehicle via the ODB2 port in the footwell of the car. After plugging the HSM into the ODB2 port, the user can toggle a switch to load the factory or the adjusted ride height. After a few seconds, the new setting is uploaded and the car will adjust to the new height. The factory setting will always be stored on the HSM and the user can set the vehicle back to the factory setting. Once the settings are loaded, simply unplug and store for future use. With the newest update to HSM, the user is now able to adjust the suspension settings directly in the on-board command system in their Mercedes. After plugging the HSM into the OBD2 port, the RennTech HSM Screen will appear on the Mercedes Command screen. After changing and saving the settings, the module can be unplugged and the screen goes back to the regular Mercedes menu. No tools, laptop or tablet needed. Full Plug'n'Play Solution. All RennTech HSMs are adjustable via USB using either Windows or Android OS.The software allows the user to adjust the ride-height at each corner in 1mm increments independently. The software also has three locations where the user can store pre-configured suspension setups for quick changes.
Features:
Allows the user to have full control over all four corners of the vehicle’s
Adjustment increments: 1mm
Maximum Lowering: Limited only by vehicle
Adjustment Methods: PC or Android (Tablet)
Size: 73mm x 44mm x 24mm
Renntech Exhaust Valve Module
Click HERE to order Exhaust Valve Module!
RennTech plug & play EVM Exhaust Valve Module allows you to open the exhaust flaps of your car 100% at all times by pressing Button 1 on the remote control. If you wish to go back to factory settings simnply press Button 2. This gives you complete control over the exhaust sound and rumble of your car at any time regardless of speed, RPM or driving mode. The RennTech Exhaust Valve Module is made in Germany. If your car is equipped with factory exhaust flaps, with or without a center console button to open or close them, factory settings do not allow the flaps to fully open unless certain speed and/or RPM have been reached. For example, while cruising the exhaust flaps will never fully open.
Features
Activation completely independent regardless of drive mode
Override your cars factory exhaust flap setting with the push of a button
EVM does not engage with CAN-Bus
No interference with any control units.
Software updates do not interfere with the functionality of the EVM exhaust valve module.
Plug and Play with original plugs
No cutting wires, no damage to factory cables, fully reversible
1 x Exhaust Valve Module
2 x Remote Controls (Button 1 fully open, Button 2 back to factory)
Wiring harness (model specific)
Installation manual
Renntech Aero Carbon Fiber Decklid Spoiler
Click HERE to order Decklid Spoiler!
RennTech is proud to introduce an all new rear decklid spoiler design for the Mercedes-Benz S-Class. This highly integrated pre-preg carbon fiber spoiler compliments the sophisticated and refined S-Class exterior design language. The spoiler is coated inside and out with an all new acrylic UV protection system. A second layer of UV protectant clear coating is also applied using traditional spray methods. The rear spoiler integrates seamlessly into the rear of the vehicle and offers a dramatic, unique appearance to the rear exterior. RennTech is proud to introduce this sporty yet elegant rear deck lid spoiler for the S-Class. The rear spoiler integrates seamlessly into the rear of the S and offers a dramatic, unique appearance to the rear exterior. RennTechfull carbon fiber spoiler is manufactured from extremely high quality, prepreg carbon fiber and available in both matte or gloss finish.
Features
Stunning good looks of vehicles
High quality meterials used
Looking more aggressive
Carbon Fiber meterials
Design is perfect
Simple to install
Renntech Performance Package
Click HERE to order Renntech R1 Performance Package!
Click HERE to order Renntech R2 Performance Package!
Click HERE to order Renntech R3 Performance Package!
The RennTech R3 Performance Package is the evolution stage of the R2 Pkg. Included in the R3 Package are all upgrades from the R2 Pkg, ECU Upgrade, Diverter Valve, Air Filters, Carbon Fiber Air Box Kit and Stainless Steel Sport Mufflers, as well as upgraded Turbocharger. With the upgraded Turbochargers included in the R3 Performance upgrade, RennTech is able to add up to 185 HP and 231 LB-FT to the 5.5L V8 BiTurbo engine (compared to RennTech rated stock performance). The addition of the upgraded diverter valve helps the engine to handle boost spikes in high boost pressure applications better. A surplus of boost will be released to the atmosphere and the turbocharger can be supplied with air quicker after the shifting process. This helps to eliminate the 'Turbo Lag'. The RennTech 4-piece air box kit is made out of the highest quality pre-peg carbon fiber. The kit comes complete with flow optimized turbo tubes to increase the volume of incoming airflow. Our Stainless Steel Sport Mufflers are hand crafted and 100% desgined and produced at the Stuart, Florida Headquarters. Made out of T-304 stainless steel (SS) with 2 3/4" tubing, they offer lighter weight and improve performance by reducing back pressure, increasing exhaust gas flow and cylinder scavenging. RennTech upgraded turbochargers are equiped with lightweight forged billet wheels and feature a dramatically larger than stock impeller (inlet side) and an increase in the turbine trim (exhaust side). This combination of high quality, light weight components coupled with less rolling resistance from the ball bearing cartridge compensates for turbo lag despite being a functionally larger turbo. The cartridge supporting shaft is also both larger and stronger designed to handle the larger wheels and added power. This entire cartridge is then fine balanced as a complete assembly to compensate for these increases. The impeller and turbine housings are then precision CNC machined and flow tested in-house to fit the larger internal cartridge. The R3 performance package increases performance to 790 hp and 895 lb-ft at the crank, without sacrificing daily driver comfort or reliability and offer huge gains across the entire RPM range.
Features
Lighter weight exhaust
Improve performance
RennTech ECU Upgrade
RennTech 3rd Gen. Diverter Valve
BMC High-Flow Air Filters
RennTech Carbon Fiber Air Box
RennTech Stainless Steel Sport Muffler
RennTech Turbocharger Upgrade
Renntech Exhaust Stainless Steel Sport Muffler
Click HERE to order Stainless Steel Sport Muffler!
RennTech stainless steel (SS) sport mufflers are hand made and rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle. RennTech Sport Mufflers are made out of T-304 stainless steel (SS) and 100% hand crafted in the USA. This exhaust system is rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle. RennTech mufflers with 2 3/4 inch diameter tubing offer lighter weight than the stock exhaust and improve performance by reducing exhaust back pressure, increasing exhaust gas flow and cylinder scavenging.
Features
Improve performance by reducing exhaust back pressure
Lighter weight than the stock exhaust
Improving exhaust gas flow
Gains up to up to 10 HP & 15 TQ
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
Click HERE to order Performance Transmission Softwares Upgrade!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability
Shift timing
Renntech Performance Carbon Fiber Airbox
Click HERE to order Renntech Performance Carbon Fiber Airbox!
Click HERE to order Renntech Performance Carbon Fiber Airbox With Turbo Charger!
RennTech optimizing the path and increasing the volume of incoming airflow, RennTech carbon air box is able to offer gains up to +10 hp and + 10 lb/ft, in addition to serving as an attractive under hood showpiece. RennTech kit comes complete with high flow performance filter inserts and anodized aluminum MAF sensor retaining clips. Using the highest quality pre-preg carbon fiber, our 4-piece airbox kit for the 63 series biturbo M157 engine comes complete with flow optimized turbo tubes to maximize engine performance by increasing the volume of incoming airflow. The carbon fiber airbox was designed, engineered and manufactured in the USA using only industry leading materials to ensure long lasting durability and appearance. The Carbon Fiber Air Box kit includes a Set of 2 BMC high performance air filter. RennTech electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that RennTech proprietary air box offers incredible performance gains and rock solid daily driver reliability.
Features
Increasing the volume of incoming airflow
High flow performance filter inserts
Gains up to +10 hp and + 10 lb/ft
Carbon fiber material used
Renntech Carbon Fiber Airbox
Renntech Turbo Charger
Renntech Performance Diverter Valve
Click HERE to order Diverter Valve!
RennTech 3rd Generation Diverter Valve for the M157 5.5L V8 BiTurbo features an all-new Blow-Off Valve implemented into the re-designed OEM turbo tubes. The Diverter Valve releases the boost in high-boost situation and/or boost spikes. This especially helps during the shifting process, for faster shifting and a quicker boost response for the next gear. It helps to eliminated the so called 'Boost Lag'. With the installation of the RennTech Diverter Valve, they are able to supply the engine with more boost pressure in order to gain higher HP numbers. The turbo tubes are ceramic coated in titanium to sustain high temperature and provide a more aesthetic look in the engine bay
Features
Helps to eliminated the so called 'Boost Lag
Helps during the shifting process
A quicker boost response
Higher Horsepower
Faster shifting
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
Old Nov 12, 2019 | 01:11 AM
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
are you running any deals or are those the prices? Same prices as renntech website
Old Nov 12, 2019 | 02:14 PM
AutoTalent's Avatar
SPONSOR
G55
Sent you a PM!
