S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
Trickle charger
Old Dec 29, 2020 | 09:15 AM
Scott1217's Avatar
S 63 AMG
Trickle charger
Hello all:
Up here in the Northeast, with all the salt and snow and crappy drivers, I have put my car on the lift for the winter. It will be hibernating for the next three months, until it warms up enough to be able to start washing it on a regular basis. In putting the car away, I have put a trickle charger in the car. It has been plugged in to the cigarette lighter. Not sure if this will work, or do I need to pop the hood and connect it to the battery? Any information on this would be quite helpful.
Safe, Healthy New Year and thankx, in advance for any assistance in this regard.
R\
Scott
Old Jan 2, 2021 | 08:13 AM
Scott1217's Avatar
S 63 AMG
Thank you! Made the switch yesterday!
Old Jan 28, 2021 | 12:19 PM
erikjep's Avatar
2017 S63 AMG Cabriolet 4MATIC
I have mine connected to the outlet in the trunk; unlike the lighter, it's on all the the time. And you can close the trunk w/o damaging the cable.
Best choice for the battery we have:
https://smartercharger.com/collectio...tek-lithium-us
By the way, how do you take care of the Cabriolet's fabric roof?
Good luck.
Erik
Old Jan 28, 2021 | 01:06 PM
Gazwould's Avatar
S204 C250 CDI Sport
Damn , you don't get a display screen for your dollars !
Old Jan 28, 2021 | 01:15 PM
erikjep's Avatar
Nope. Just the pretty lights. It does the job well, however.
Old Jan 29, 2021 | 08:56 AM
Scott1217's Avatar
S 63 AMG
Hi Erik:
Thanx for the help. The car is on the lift and I have attached a charger/maintainer under the hood.........just don't close/lock the hood and all is fine. I will remove it in March as she awakens from her winter hibernation.
BTW: mine is a 4 door, so I can't help you with cabrio top maintenance. I would suggest Griots Garage, AMMO NYC, Obsessed Garage are good places to start......good luck.
R\
Scott
Old Jan 29, 2021 | 10:44 AM
erikjep's Avatar
Hi Scott:
Thanks for the tips; you probably saved me from damaging the convertible's top. Griot's has the right product for it. As one customer puts it: "I also like the fact that this product is not damaging to rubber or vinyl. One competitive product that is frequently used on convertible tops has a warning that it damages rubber and vinyl. Since many convertible tops are constructed with an inner rubber layer, this could cause a problem." That was precisely my concern!
Can't wait for the good weather. Thanks again.
Erik
Old Jan 29, 2021 | 12:45 PM
coolcamden's Avatar
2021 E63S Wagon 2019 S63 AMG Coupé 2015 S Coupé Edition 1 1970 Chevelle LS5
Scott, can you post pictures of your set up, along with the charger used?
Old Jan 30, 2021 | 12:15 AM
Gazwould's Avatar
S204 C250 CDI Sport
With a screen you get starting voltage and charged up voltage a great piece of info on how healthy the battery is .
With 3 to be concerned about the oldest and only original battery starts off the lowest and charges up to the lowest readings meaning it's days are limited .
Old Feb 1, 2021 | 08:31 AM
Scott1217's Avatar
S 63 AMG
Let me see if I can climb up on the lift and get you a pix or two.
Old Feb 1, 2021 | 02:20 PM
erikjep's Avatar
Actually, the lights reflect status as well. For instance, 8 lights on = All's well, 1-3 on = Get ready to spend $1,400 on a new battery...
Old Feb 3, 2021 | 12:38 PM
Scott1217's Avatar
S 63 AMG
erik
not sure if this is what you were looking for. The charger is under the hood.
Old Feb 3, 2021 | 12:50 PM
erikjep's Avatar
Scott:
I think you meant this reply to coolcamdem. Nice looking car.
Erik
Old Feb 3, 2021 | 01:14 PM
coolcamden's Avatar
Scott, thanks for taking the picture. I was hoping to see where exactly the hook-up is under the hood/trunk.
