S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
Airmatic compressor fuse blowing but not instantly
Old Aug 28, 2022 | 01:40 AM
andre46's Avatar
2015 S63
I got the yellow malfunction light one night while diving and when I stopped, the front end was dropped low.
Ended up being a blown fuse, so I replaced it with a fuse with identical ratings. It worked to raise the car back to normal level but blew again after a little driving resulting in the rear dropping low this time.
Replaced it with a fuse from the dealer and it worked perfect for a day, raising and lowering the car no problem but blew the next day and the front is low again.
Replaced it with a similar fuse as the first time (since it’s the weekend and dealer is closed) to get some air in and get me home. The compressor worked for about a minute (maybe less) and the fuse blew.
Anyone have any ideas why the compressor would be working only for a short period of time (longer with Mercedes fuse, shorter with generic fuse) before blowing?
Old Aug 29, 2022 | 09:53 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Sounds like a bad pump, drawing too much current and blowing the fuse. I would start there.
Old Aug 29, 2022 | 09:56 PM
andre46's Avatar
2015 S63
i ended up taking the compressor out yesterday and it wouldn’t turn at all after applying 12V. Opened it up and there ended up being an a short on the motor because the winding insulation was burnt. Dealer quoted me $1750 (Canadian) for the part so I went aftermarket with lifetime warranty with relay and filter for $450.
