S63 noise
S63 noise
Hi Guys,
I have a Mercedes S63L W222 2016 and recently started to experience some some noise at the front passenger side wheel.
Any suggestions on culprits behind the noise?
See video.
Things I have checked:
Just after some suggestions to where I can look
thanks
See video.
- Xentry not showing any fault codes.
- Noise appears when accelerating and sometimes at stand still.
- Testing ABC suspension levelling by raising the car, no noise when this happens.
- Braking seems fine when driving.
thanks
If it is doing that when you turn the wheel in either direction and while moving it sounds like a wheel bearing. I think there is a TSB for this as I had the same problem with my 2019 S63. It made a ticking noise when turning the wheel in either direction and moving slowly forward or backwards. They had to remove the bearing and inspect it with either a bearing repack or a new bearing fixing the issue.
I managed to get the costing for the bearings today: £205 per wheel bearing assembly here in the UK for the front side.
Hopefully it is that and nothing else.
