S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
S65 Lowering Module
Old May 15, 2023 | 01:54 PM
Teejay3726's Avatar
S65
S65 Lowering Module
I am looking for a lowering module for my 2017 S65. Looks like the only option I can find is RENNtech that makes one for an S65 because of the magic body control.
Am I missing any other options I should consider?
TJ
Old May 15, 2023 | 07:58 PM
BigApe's Avatar
2105 S63 Full Carbon - 2018 GTR
check this one out. works perfect on both of my 63s. not 100% sure on the 65 but worth the peek.
ELM ELM
Old May 15, 2023 | 08:05 PM
BenzNinja's Avatar
Former Vendor
TJ
You can get your car lowered with us for $250 lifetime
Old May 15, 2023 | 08:16 PM
Teejay3726's Avatar
S65
Originally Posted by BigApe
check this one out. works perfect on both of my 63s. not 100% sure on the 65 but worth the peek. ELM
thank you for the reply! Unfortunately that is for the airmatic in the S63. The S65 has magic body control as a standard feature and these won’t work on it.
Old May 17, 2023 | 06:47 AM
garyharbon's Avatar
c class
Did you look through shops in your area ?
Old May 20, 2023 | 08:20 PM
aaslanmd's Avatar
2016 AMG S63V4 + 2019 Corvette ZR1 + 2003 Suzuki Anniv Hayabusa + 2003 Harley Anniv VROD
TeeJay,
Try LoweringModule.com
(424) 234-6569
They can recommend installer closest to you as well!
I have it on my 2016 S63: module was hardwired hidden behind passenger-side footwell; controlled via steering wheel buttons, wide range of adjustment.
No electrical/check engine lights issues + OBD port untouched.
About $1600. + installation.
Highly recommended: perfect stance for my purposes, works for everyday driving + you can still use lift button on console for addt'l 2" lift.
Good luck!
Alex
