S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
REPLACING MASSAGE/DYNAMIC SEAT PUMP ON S CLASS W222
Old Jun 15, 2023 | 08:59 PM
2005s5004matic's Avatar
s500
HI ALL,
I RECENTLY PURCHASED A 2015 S65 W222 WITH NON WORKING MASSAGE/DYNAMIC SEATS. I FOUND ONLY ONE CODE FOR GROSS AIR LEAK...AND I CAN COMMAND THE AIR PUMP IN THE TRUNK TO COME ON...BUT NO PRESSURE WAS BUILDING IN THE RESERVOIR AND THE PUMP WOULD TIME OUT AND SHUT OFF. I ALSO REPAIRED A HOLE I FOUND IN THE AIR HOSE UNDER THE DRIVERS SEAT. STILL GOT THE ERROR CODE FOR LEAK.. SO I SMOKE TESTED THE PUMP AND IT WAS LEAKING. SO I ORDERED A NEW PUMP AND SHOULD BE GETTING IT SHORTLY.. MY QUESTION IS WHETHER OR NOT THIS NEW PUMP...CALLED CONTROL UNIT...NEEDS TO BE CODED TO THE CAR?? I HAVE REACHED OUT TO SEVERAL MERCEDES DEALERSHIPS AND HAVE BEEN TOLD CONTRACDICTORY THINGS!! HAS ANYONE ON THIS FORUM REPLACED A W222 MASSAGE SEAT PUMP AND HAD IT WORK WITHOUT GETTING IT CODED BY THE DEAL? OTHERS HAVE A;SO SUGGESTED THAT ONLY THE MERCEDES STAR SYSTEM CAN CODE THIS AIR PUMP AND NOT MY EXPENSIVE LAUNCH BI DIRECTIONAL SCANNER.
ANY SUGGESTIONS WOULD BE APPRECIATED.
THANKS,
RICK
Old Apr 14, 2024 | 05:16 PM
06SL500AMG's Avatar
2006 SL500
Did you ever get your massage function sorted out?
Old Apr 16, 2024 | 08:35 PM
s500
Yes...after replacing the leaking air pump in the trunk with a new unit from Mercedes....the new pump had to be coded by the dealer. All is working well now...hope this helps,
Old Jun 28, 2024 | 07:57 AM
Bernardy's Avatar
Mercedes S Coupe, Porsche Macan
Hi,
Would you still have the part number for the pump. I'm having the same issue.
Old Jun 28, 2024 | 08:41 PM
s500
Hi,
The part number is 222-900-41-15. After I installed it....it needed to be programmed to the car by dealer software.
Good luck!!
Old May 14, 2025 | 02:25 AM
ZayMajor_4's Avatar
2016 AMG s63 Coupe
Preciate it bro i was having the same issue
Old Oct 14, 2025 | 01:19 PM
Bernardy's Avatar
Hi. Did you ever get the part? I ordered two in error and have the extra one if you are still looking for the part,
Old Dec 5, 2025 | 12:47 PM
Yeezus's Avatar
E350
I can buy the other one if you have it still?
