S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
2015 S65 AMG FUEL FILTER LOCATION??
Old Feb 16, 2024 | 11:25 AM
2005s5004matic's Avatar
s500
Hi all,
I recently purchased a 2015 s65 AMG with 45k miles and I would like to replace the fuel filter as part of the maintenance. I have checked online retailers but have been unable to find either the filter or where on the car it is located. Can someone please advise where the fuel filter is.
Thanks for your time,
Rick
Old Feb 17, 2024 | 06:16 AM
Hendrik Koster's Avatar
Top Answer: 1
2007 S65 AMG-Sold, 2007 SL55 P030 - 2016 GL450 - - 2017 AMG GTS - Sold - 2015 AMG S65
Fuel Filter
Originally Posted by 2005s5004matic
Hi all,
Rick
I have replaced the fuel filters on an S63. Access is under the rear seat, and the filter is the integrated part of #50 (see attached parts information PDF). I assume the S65 is the same.
Best HK
Old Feb 17, 2024 | 07:18 AM
s500
Hi HK,
Thanks for the help. I guess the filter is part of the entire fuel pump assembly then? Odd that the filter itself isnt sold separately...dont believe a fuel pump needs to replaced at only 45k miles.
Will have to contact the dealer parts dept and ask.
Thanks again,
Rick
Old Jan 9, 2025 | 07:20 PM
s500
Hi All,
I would like to replace the gas filter on my 2015 S65 and believe its located under the rear seats..but i haven been able to find a replacement online and not sure if the filter is part of the pump assembly or is a stand alone piece. Can anyone let me know if the fuel filter is a stand alone piece or does the entire pump assembly need to be replaced? The car has 46k miles but I am the 2nd owner and not sure of the history/maintenence,
Thanks,
Rick
Old Jan 10, 2025 | 07:57 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
W222 fuel pumps have a filter mesh on the pump which should apply to the 63 and 65 vehicles. It's not really a part of routine maintenance the way it used to be with the mechanical fuel injected cars with the in-line filter under the car with the lil hoses clamped to them. They pretty much will do their job until the pump dies. It's also like a $500 unit.
2224700094 for Mercedes-Benz Maybach S550 W222 S63 AMG S450 Fuel Pump  Assembly | eBay
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
