S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
Factory camber rear
Old Feb 1, 2025 | 09:48 AM
Finn Donati's Avatar
Mercedes-AMG S65
Factory camber rear
Hey
What is the correct camber-angle on the rear axle?
V222 S65 2015
Old Feb 1, 2025 | 03:41 PM
Quadrobenz's Avatar
'94 SL600,'05 SL600,'06 S65,'07 E63,'14 E63S,'09SL600 all sold, ‘15 S65,‘18 E63S,'17 SL65, '17S65Cab
Here is a complete Alignment data sheet for my W222 S65. You want the numbers in the Target Data column.
Old Feb 1, 2025 | 07:48 PM
Mercedes-AMG S65
Perfekt! Thanks
Old Feb 1, 2025 | 11:09 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
All W222 models including performance AMG S63/S65S - have no rear Camber adjustment (or Front Camber & Caster) OEM !
All to do with ever increasing speed of new car assembly lines. Onus now back on owners to fund costly, premature tire replacement.
No longer “ongoing adjustment” capability to suit your particular driving conditions.
Whether it be high cambered roads with excess passenger side edge wear or altered height - load carrying / lowering and “inner” edge wear both sides. Excess “outer” edge tire wear through spirited driving or just having adjustment to cater for curb knock damage.
We saw the need therefore to re instate Front Camber and Caster along with Rear Camber (and Extra Toe).
Specially designed BOLT-ON kits that require no special tools or NEED FOR CONTROL ARM REMOVAL.
AMPLE ADJUSTMENT RANGE - up to 2 degrees “extra” Positive or Negative Camber. More than enough to resolve excess edge tire wear issues.
K-MAC unique patented design allows easily accessible single wrench precise adjustment. ULTIMATE - direct on alignment rack UNDER LOAD.
SEE SPOILER
Spoiler
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings (and Costs) Since 1964 !
Old Feb 2, 2025 | 04:22 PM
Mercedes-AMG S65
SEE SPOILER
Spoiler
Spoiler
Allready got a set of adjustable camber-arms (and for less than a third $). But thanks anyway.
Old Feb 2, 2025 | 08:54 PM
K-Mac's Avatar
SPONSOR
Do point out for rear suspension - yes we also manufacture “Upper Camber arms” !
In fact to suit virtually every model Mercedes Benz and unlike majority of brands not extruded aluminum but high strength chromoly steel (especially important for heavier W222, W223 and Maybach models). Also these K-MAC rear Camber arms include “extra Toe adjustment”. Same as our lower arm adjuster to compensate for Camber change. Kit #502226-5M $595.
We do not promote - as more time consuming to install along with more difficult to access to precisely adjust.
Versus lower arm adjustment - no arm removal and easily accessible single wrench adjustment - direct on alignment rack UNDER LOAD !
Also the added disadvantage re upper arms - (when wanting to resolve excess inner edge tire wear) - Reduces important clearance “top of tire to outer fender” !
Therefore only recommend if the need to “INCREASE” (not reduce) excess negative rear Camber.
SEE SPOILER
Spoiler
AUDI to VOLVO - Experience Resolving OEM Suspension Shortcomings (and costs) Since 1964 !
Old May 11, 2025 | 04:05 AM
zk2004mb's Avatar
S63 Coupe
Sorry, posted wrong information here, please ignore this reply.
