S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
RPMs dropping when coming to a stop
Old Sep 20, 2025 | 11:23 PM
The Truth's Avatar
2015 S63 & 2014 ML350
I've noticed lately that my RPMs will drop momentarily when coming to a stop and then shoot back up before coming to a normal idle when stopped. I also notice that stepping on the gas and the car will actually studder a bit as I accelerate while in second gear. I know that in Comfort mode, the car will start in second gear so you always have to give it a bit more gas to get going, but this doesn't seem right. I think about six months ago the actually stalled when the RPMs dropped so low when I trying to get out of a parallel parking spot. I've recently had the spark plugs changed hoping that would fix the issue, but no joy. I was going to look at maybe replacing the MAF sensor or 02 sensor if that's applicable to see if it helps. Also, maybe a vacuum leak somewhwre...not sure.
Old Sep 25, 2025 | 03:20 PM
dimey357's Avatar
2015 s63
I think there was a recall stating something about a software tune that corrects stalling when coming to a stop. I recenetly purchased a 15 s63 and the previous owner had a recall paper that mentioned something about this.
Mercedes-Benz S63 recall tune (2014–2016 models)
  • The issue: On certain AMG S63 sedans and coupes from 2014 to 2016, a software error in the Engine Control Unit (ECU) could cause the engine to stall when slowing to a stop. The stall might be mistaken for the "ECO start/stop" function, but the engine would not restart, immobilizing the vehicle. This affected 2,943 vehicles from the AMG unit sold between November 2014 and September 2015.
  • The fix: Authorized Mercedes-Benz dealers will perform a free software update to the ECU to correct the issue.
Old Feb 17, 2026 | 01:07 AM
Nadasive's Avatar
2017 S63 AMG (W222)
My 2017 s63 does the same thing
did you end up getting the software update?
Old Feb 17, 2026 | 01:16 AM
Nadasive's Avatar
2017 S63 AMG (W222)
Let me know what happened. Im going to start with a throttle body cleaning and a throttle adaptation reset
Old Feb 17, 2026 | 02:17 AM
The Truth's Avatar
I never ended up getting the throttle body cleaned. I did however have an ignition coil fail, so that seemed to help a bit after changing it out. It still however will dip when coming to a stop, especially on a hill but it always kicks back up and returns to normal without the car stalling. Let me know how it goes as a throttle body cleaning is my next thing to work on. I just finished getting the drivers side door soft close fixed so the throttle body cleaning should be next.
