S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
2016 S63 chauffeur mode not fully working
Old Apr 4, 2026 | 09:31 PM
VelocceS63's Avatar
Hello all, my s63 currently has an issue where the headrest doesent fold forward all the way, the most it goes forward is shown and the footrest doesent come out (shown in images) when chauffeur mode is in use. The seat still goes forwards and the headrest is still operational. Any help is appreciated
Old Apr 5, 2026 | 11:47 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
you'll need a scanner like xentry to see what sensor is not reading right
Old Apr 7, 2026 | 12:01 PM
vincheung's Avatar
S63, GLE580, BV250
Happened to me in the past also, as Balti mentioned, it'll need to be xentry'd. For me, I had the headrest removed, wasn't able to re-insert it, and footrest didn't extend until everything was reset w/ proper software.
Old Apr 7, 2026 | 12:36 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
This CAN vary based on what key you are using. We setup the car(s) blah blah blah...I am not as sensitive as my wife. Well, all of a sudden none of her setting were working...fast forward some weeks they all of a sudden worked again. She was holding the proper key fob. If I am not mistaken the position of the sideview mirror switch was also involved (seriously).
Old Apr 8, 2026 | 03:46 AM
yagey's Avatar
2007 cls 63
in your case I suspect the drivers door window switch cluster or connector was related
@VelocceS63 while it may sound obvious - double check (bang on) your back-seat lockout switch on drivers door panel and wiggle door wiring connector loom if you don’t have ready access to reset and test the seat position via xentry (resetting mine fixed the cooling function fwiw)
Old Apr 9, 2026 | 01:19 AM
VelocceS63's Avatar
Is this a common issue because I’ve checked the forums and I’ve only found one similar and it required them to remove the headrest.
