New Renntech ELM question
Old Mar 23, 2008 | 01:33 PM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
Originally Posted by jimmydagreek
You got if for $800 right, not $700, lol...
If I remember it was 7..or might of been 8..I forgot..
Old Mar 23, 2008 | 05:59 PM
psk145's Avatar
2006 E55
won it for 700, told you it was 800.
Haha, just kidding
Old Mar 23, 2008 | 06:26 PM
Vader13's Avatar
Haha, just kidding
Happy Easter bro!
Got a blacked out grill today! woot!
Old Mar 24, 2008 | 11:45 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Noooo, lol, I was at $700 and your buddy came in at $900 which pushed Mike and I out (we were bidding against each other, lol). Then when I glanced at the paper at the end he changed it down to $800 without anyone looking, lol.
Old Mar 24, 2008 | 01:00 PM
  #30
psk145's Avatar
2006 E55
Yeah, Im sorry. I never did a silent auction before. For some reason I thought it was ebay.. After I thought about it, I went back and changed it. Some people had crossed their bids out on other items, so I thought it would be OK to change it. In my defense though, they did give plenty of opportunity to bid before closing it off.
But I would have bid it to $1K anyway. Even at $1K, still a steal, and all to a great cause. I wish I could get all my mods this way, if so, I would be completely tricked.
Old Mar 24, 2008 | 02:16 PM
  #31
I agree, you got a great deal and it all does go to charity in the end! I won the CF E55 front lip for $200 bucks so I'm still content, lol...
Old Mar 24, 2008 | 02:41 PM
  #32
Vader13's Avatar
Wow good for you..we paid 8..and we killed it.
Old Mar 24, 2008 | 11:50 PM
  #33
jangy's Avatar
2015 S212
Originally Posted by zoink
Not sure whether this should answer it....
If I read the instruction manual (http://www.renntechmercedes.com/lm_i...ions/mb_lm.pdf). It seems that up W211 up to 4/06 build date has 4 sensors vs. 3 sensors on 5/06+ build date
Dunno where you read that, but it is not true. i have been all over the W211s and haven't come accross a 4 sensor yet. Again, that is airmatic. ABC has 4 sensors.
You're right, reading the instruction, it seems that you basically just move the wire... so instead of naked wire-to-wire connection, it would just use an adapter that has to be connected manually? Why can't R/T create a true PnP?
Because this was much cheaper. I'm still not sold on the gen II. I'd like to be able to buy the GEN I rights from them. i bet I could sell a snot load more of them than the new one at double the price.
Old Mar 25, 2008 | 12:08 PM
  #34
DO IT!
Old Mar 25, 2008 | 12:09 PM
  #35
psk145's Avatar
2006 E55
wait, our cars only have 3 wires? I wired mine for 4 wires because of the instructions. So are the instructions incorrect?
My assumptions: 2003-4/06 were 4 wire
from 5/06 on, they were 3 wire.
Someone please clarify!
Old Mar 25, 2008 | 03:07 PM
  #36
Vader13's Avatar
Old Mar 25, 2008 | 11:00 PM
  #37
neveo's Avatar
05 e55
Originally Posted by Vader13
Your factory Airmatic settings might be off if you can't get it straight.
Or you need to set the car up on a perfectly flat ground.
Or just set it at whatever seems to work best..
i have the same problem driver side rear sits lower than passsenger rear... my settings were 3/3/6 indie found sds error code for front driver side mb airmnatic leveling sensor. took it to dealer for free replacement and fuel filter recall with the elm turned off and they said they reset it.... got home turned the elm on and back to the 3/3/6 setting and the rear driver side is still off...
can an indie fix this with the sds system ? its off not more than a half inch... didnt have exactlly level ground but the car appear a more level when the elm was off ...
other than measure on a total level floor in the day time any help would be appreciated
Old Mar 25, 2008 | 11:12 PM
  #38
Vader13's Avatar
Thats pretty off, a half inch? try different settings to leval it off?
Old Mar 26, 2008 | 07:06 PM
  #39
neveo's Avatar
05 e55
remeasured today and it's a quarter of an inch difference.... will take iut back in am for re calibration
Old Mar 28, 2008 | 12:22 PM
  #40
neveo's Avatar
05 e55
all fixed, replaced a defective sensor, and had all recalibrated....everything level,
Old Mar 28, 2008 | 12:37 PM
  #41
Vader13's Avatar
I have mine set up pretty wacky in the rear, to have it leval, one is on 3 and one is on 5...the front is the same. at 2
Old Mar 28, 2008 | 12:57 PM
  #42
psk145's Avatar
2006 E55
can anyone clarify the 3 wire vs 4 wire??
Old Mar 28, 2008 | 01:04 PM
  #43
neveo's Avatar
05 e55
mine is 3/3 front and 6 rear. i thought for the airmatic there are only 4 knobs... 2 for front ,1 for rear and next to that the rear an on off knob which is numbered as 0 for off, 1 for airmatic and 2 for the non airmatic..... i was told the following... either the leveling sensors for the airmatic are faulty /going bad and need replacement and or they need to be reaclibrated if they are off... my idie did it in less than an hour.....
Old Mar 28, 2008 | 05:25 PM
  #44
Vader13's Avatar
There is 4 knobs, I posted a pic of it above in the thread. I had them all at zero lol
Old Mar 30, 2008 | 11:48 AM
  #45
jangy's Avatar
2015 S212
Airmatic vs ABC
Old Mar 30, 2008 | 07:24 PM
  #46
psk145's Avatar
2006 E55
Airmatic vs ABC
pretty vague.
I wired my car per the "4 wire airmatic" instructions.
Is the manual wrong? You claim you haven't seen a 4 wire setup
Old Mar 31, 2008 | 11:58 PM
  #47
jangy's Avatar
2015 S212
pretty vague.
I'd check that, charles. Your Airmatic only has 3 sensors.
I don't claim, it is simply impossible. ABC has a sensor at each wheel. Airmatic in the E55 has one at each front and one in the center of the rear. There are no other sensors. I do not know how the new S runs on Airmatic. the older S never had it. they all had ABC.
I do not know if RT's manual is incorrect, but I think I remember that the last set of instructions mixed up some colors with the wire numbers. I also think i remember someone with the new one saying that the colors are off on the new one, too.
Old Apr 1, 2008 | 12:55 AM
  #48
psk145's Avatar
2006 E55
Thanks for the clarification arjang. I'm gonna call rt tomorrow and find out WTF. Their manual shows 03-5/06 as being 4 wires.
Old Apr 1, 2008 | 09:32 AM
  #49
jangy's Avatar
2015 S212
They could be power buttons? I dunno. All I am sure about is the number of sensors and that the new S has Airmatic as well (but it may be different).
Did your elm work? With the older one, there are two different "on" settings to determine which setup you have. In all honesty, I don't think it made a difference in my car which on it was on, as long as the 3 sensor wires were on.
Old Apr 1, 2008 | 12:58 PM
  #50
psk145's Avatar
2006 E55
elm works, but I noticed the other day, when I turned it off, the car sits lopsided. The left side is higher than the right. Way higher.
