Lth mhp v3 vs shorty kleeman Eurocharged tune tune
Hi everyone
I have a lil problem but it seem no one can help so i need u guy.During 1 year had 2 set up, one was shorty Kleeman header with Eurocharged tune and the other is LTH from Mhp along with v3 tune from Andy.Here is the problem and regret not dynoing when i was stock.I did 2 dyno with the same shop same dyno.Each of them different set up but had less with the Mhp set up more like 415 or 418 if my memory is correct.I know Eurocharged came to Montreal for tune and dyno day over the week end so i waited to see if my number are correct compared to other c63.Now i know my number are low so i am trying to figure out the problem why?? People were having same number as i with only a tune 400-415 hp to the wheel without p31 and there was even a 443hp with p31.I am really conservative but there is a 20-30hp somewhere missing.Could that be the tune??or something is wrong with the car??Oil was changed prior to each dyno day.So everyone help me out on this one.
thanks in advance.
thanks in advance.
Hi everyone
thanks in advance.
thanks in advance.
i recommend the same thing . we did a commercial , here in town , for the speed shop that does all my work . my car was on the dyno and did one run for the commercial and i got 458whp out of mine . i know it has a little more in it but that was just done for the commercial . your numbers should be a lot higher
just so I have the facts right,
Eurocharged tune with kleemann headers made more power then your current MHP tune with MHP long tubes, and Andy at MHP isn't helping you out, unless you pay more $$
you should have asked Mike when he was in Montreal to custom tune it for you !!
Have you tried another dyno location or brought the car to the track to see what it traps?
I brought my car to a local dyno once.. I dyno'd 363RWHP. This was with a Renntech Stage2 tune of claimed 511HP.
If you do the math on 511HP with 18% loss: I should see 419RWHP.
Obviously I was choked and a bit pissed off. So I took the car to the track and I was trapping consistent 118-119Mph speeds. That is bang on for a P31/Tuned car, and up 4-5Mph from my stock configuration. So obviously my car was tuned and the guys dyno was just way off or something wasn't right.
I now take dyno numbers with a grain of salt.
Yes my current set up made less,i spoke to Andy asking why but he was saying that the dyno place didnt know how to dyno car and giving **** to this guy(he was sayin there was lack of air).Andy is a good guy i have nothing bad to say about him. Just trying to figure out my problem.Sorry i forgot to mention.I recently know Mhp has a new update tune i called Andy and he said xxx$ for an update.I thought it was free lol.No worry i am working with Mike now and waiting his call.
hope everything works out for you in the end
for example, you buy brake pads (say A brand) from Benz (MHP), and the pads make noise, and Benz changed their supplier in Germany (brand B)... as a customer of Benz (MHP)..would you expect Benz (MHP) to turn you away and say you have to pay extra for pads..
Andy needs a lesson in Customer Service
Whether he switched tuners or not, I still think Andy should help out the guy, Its just commen sense isn't it, he was a customer...
A better example would be if you purchased a size Large shirt, but it turns out they sent you a small. Then they should have to give you the item you intended to purchase. In this case, the OP purchased headers and tune that were supposed to give X amount of gains, but only delivered Y. Before fretting, the OP should go and verify his hp by going to another dyno shop or verifying at the track.
GL to the OP!
Trying to follow you dynoed your car 2 times? Once with kleeman and once with mhp? Why do you think it needs a reflash? The techtec file mated with the longtubes are proven real world by many, dynoes are not that good there are many different things that could have changed in a years time? Temp humidity? Can you post both dynoes this would def, help include the address of the place we can look at da first and foremost
I agree with what you're trying to say, but that's a horrible analogy that you have used. If you buy brake pads, use them and end up not liking them, why would any seller have any obligations to take them back and offer you another set for free? These are tangible items that have greatly diminished in value.
GL to the OP!
GL to the OP!
I would say its more like buying a 2011 c63 then hearing better things about the 2012 and expecting to get it upgraded for free? Kent Andy petro Keith and I spent time and money to tweak this new and improved tune. We got a better tune now everyone wants the upgrade for free cause its new and improved
I don't think that's what the OP was implying. He stated that he is disappointed that his MHP header/tune combo only gets the same rwhp as a p31 or tune only C63. He just wants to know why he isn't getting the same HP numbers as other MHP header/tune cars. I might be wrong, that's how I interpreted what the OP was saying.
I agree with you, the OP should run his car at another dyno or at the track to verify the numbers before messing with the run files.
I don't think that's what the OP was implying. He stated that he is disappointed that his MHP header/tune combo only gets the same rwhp as a p31 or tune only C63. He just wants to know why he isn't getting the same HP numbers as other MHP header/tune cars. I might be wrong, but that's how I interpreted what the OP was saying.
The problem is there is only 2 dyno shop close to me,the other dyno shop cost an arm to get a dyno close to 350 $wich is a lil pricy.I returned to the same place only because i will have number to compare with at the end of the day.
Mike Eurocharged will come to Montreal again to put back the stock file to see if the car is run fine and then tune again.That place that dynoed my car has now lots of c63 data because over the week end it was Eurocharged dyno tune day.So i am now able to compared with other car data that was there on that day.My set up is equivalent to a 63 with just a tune how can that be?that is the only thing that bug me.Back in October i really thought there was something wrong with that dyno shop because it was reading pretty low.But after comparing my graph and all the other graph from this week end,it just drive me mad.
i understand that weather can play a difference with dyno numbers... but isn't the OP not just comparing his past dyno from a different date but he is also comparing with other c63 with different set ups on the same day with his current mhp set up? even if we say the dyno is reading low... then should it not read low for everyone else who has hopped on that dyno on that day?
