Is a "Pressure Cell" the same as the "pulsation damper"?
I was under the impression that the ABC suspension shared the same fluid as the power steering, but I guess not seeing this. I only had the ABC flushed and a new filter put in. The first pictures are the new ABC filter & fluid (fluid is green/blue on the napkin. The last two pictures are of the power steering filter & fluid. The fluid in there looks like chocolate milk and smells mildly like tar.
You always need to change both they both use the same fluid and same pump but it is not shared in the same reservoir
Change it out and even if you can't rodeo , hit the raise /lower button about 30 times.
Also you said you changed only two pressure cells. There are more . Change them all
Part for the front and rear accumulators (You need two) is: A220-327-01-15
Be advised there are two other nitrogen spheres in the system as well. One is mounted to the pressure relief valve (Part #A220-327-02-15) which is found in the front right side of the vehicle.
The other is a small nitrogen chamber (Called an Air Cell) that sits near the fuel pump in the driver side mid/center of the vehicle, (Part #A220-320-04-15).
It is my feeling that part is what's making your noise . You have replaced the three cells listed above but not the fourth cell. Plus its located right where you hear the noise coming from
if your spheres are original and you need to replace one of these spheres, replace them all as they will all be in roughly the same condition. Over time, it is normal for the nitrogen pressure to reduce due to use/leaks. If one of the rubber internal diagrams have broken, the others may be close as well.
Love this car! Even with its quirks. Fascinating to learn on!
NOW, I bounced around from two dealers, to my indie shop that only does mercedes, to another shop I like, to pep boys, to a craigslist "mobile mechanic" in my area and everyone said it was either the mounts or the power steering pump. Each shop was stern on their position. Both would cost about the same to do, and I just wanted the noise gone. Here is what I found out while I was at Pep Boys. They let me play with my car while it was on the lift.
Front-Left (driver side) ABC strut had deteriorated at the top. I guess there is a thick rubber mount(?) at the top of it, as shown in the picture. Here is a video of my strut moving around with just a lift of my tire with two fingers.
The other side didn't budge at all, and the other side's rubber mount(?) on top was in pristine shape, just a tad dirty. When the car was sitting off a lift, the top of the strut where that sensor plugs in was shoving out about an inch higher than the other side, and I could see metal because the rubber surround had broken. NO leaks in the strut, just the failed rubber mount. This caused the hydraulic line on the inner part of the strut (facing the engine) to touch the frame of my car (I found that out today after pondering for a long while). I quickly jacked my car up, reached my hand around the strut and pulled the line towards me so it almost entirely was touching the strut instead of the frame of my car. That 5 minute job took care of about 90% of that horrid noise in the other video I posted.
SO THANKFUL!
I am going to get the strut replaced and cease throwing money at this car in various places for no reason! PS, I did finish replacing all 4 dampers/accumulators, as well as the power steering fluid/filter exchange.
THANKS AGAIN GUYS!
https://mbworld.org/forums/cl-class-...op-mounts.html
I would try that First - he may even be able to send you a few rubber bushings !!!
Otherwise yes the other option is a rebuilt strut
Its an easy and really worthwhile repair. I bet most people need it but dont' realise.
Nick
Replacement parts would probably have a huge market between w215's & W220's!
Nick
