Turbo-back Down pipes
Looking inside of it, it had a lip on the lower 1/4 of the circumference I did not like so I had that ground flat. I also had it 3000 degree ceramic coated (titanium color).
It will be installed next week and soon after, a stock resonator (thanks KLR) will be welded back in. I removed the resonator, but I think I will want it back after downpipe install. I will post after coating pics later tonight
I am also decided to stick with Renntech and have then retune for the catless downpipes. I will redyno after install and add to this thread as well as the Rentech tune thread.
Anyway here are some before pics:
looking forward to seeing the results! how much did upd pipes cost?for the moment i am doing some speedriven catless dp's and re-tune with renntech until i can find some cheaper AWD turbo pipes (waiting to hear from powerhouse performance as they said they are working on some awd ones) as i cant bring myself to pay $6K for the weistec turbo pipes
I think there could be big gains up top with these pipes (5500-6500rpm my guess is 50-70rwhp gain), but it will not change the actual peak number (usually around 5000 to 5200 rpm) by much more than ~20 or 30rwhp
if that pans out, your car going to feel way stronger
So far after a couple of hard runs and left idling for about 5 mins I saw 300 to 330 degrees Fahrenheit on the stock turbo back bridge section on both sides. Let's see how the 3000 degree ceramic coating works.
Coating looks great!
E63 Biturbo, UPD Cold Air induction kit, UPD performance crank pulley and UPD adjustable rear suspension with ride height adjustment.
CL55 UPD Cold Air Boost kit, UPD 3000 stall converter, UPD 77mm SC clutched pulley and beltwrap kit, Custom long tubes, UPD crank pulley , UPD suspension kit, UPD SC pulley, Aux. HE, Trunk tank w/rule 2000 pump, Mezeire pump, UPD 5pc idler set, Aluminum rotor hats.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
It was almost stock like cruising but when you push the go pedal, you definitely hear it. Freeway was quite tame, stop and go you know something's up for sure.
Resonator went back in cos cold starts were kinda loud for 15-20seconds and I leave my house ~630am everyday
The car sounds PHENOMENAL with the stock resonator in place. The sound was RAW, loud and mean with straight pipes but with the resonator it has lost a lot of the rawness and developed a very refined tone. The last car I heard that I could compare it with was like riding in a Gallardo. It is still quite loud under WOT but you need to go WOT to hear anything intrusive at all.
The biggest change IMO seems to be at freeway speeds, it just pulls!!!
Prior to the downpipes, my car was a beast from stop or slow speeds and up. Dropping the hammer after 60 was great but nothing to write home about. With the pipes and retune (Renntech before and after), dropping the hammer at freeway speeds feels like from 20mph, just pulls and pulls hard!
It really feels like the delta change I got from stock to Renntech tune the first time around (I know I know, I did not gain an additional 80rwhp and 180rw plus torque)
been looking to gain a bit more get-up-and-go at highway speeds without going full turbo swap yet, so sounds like this is it
