Post your C450 with Aftermarket Wheels
19"x8.5" +47 // 19"x9.5" +45
Front Wheel Requires 15mm Spacer for brake and lower arm clearance.
Please note that the 15mm spacer has only been seen on HRE's scan data - NOT actually fitting on a car.
If you want the best ff the best and at a price starting at just $625 per wheel then look no further. The HRE FF01 & FF15 are your answers.
My C450 ESTATE! The same black one I have, same night package with some additional stuff apparently blacked out! DAMMIT, MERCEDES!!
You ain't never lied, thwb. They need to stop screwing with us U.S. customers and let us special order damn thing.
Irritates the hell outta me.........between tears.
Wheel width and offset is all you ever need to know to compare two wheels fitment against each other.
The offset is where the hub ends/starts.
The deviation from the centerline is the offset. A 35mm positive offset wheel has a hub mounting surface (back plate) that is 35mm away from the centerline, toward the front of the wheel.
A spacer lowers the effective offset by its thickness, as it relocates the hub mounting surface closer to the centerline. So if you use a 5mm spacer on a 35mm offset wheel, you've reduced the effective offset of the wheel to 30mm.
Decreasing the offset moves the wheel away from the strut and brakes on the back side, and closer to the fender lip on the front side.
235 will fit perfectly on my rims, not sure about 245.
275 in the rear will fit, even 285 i think will fit
