Post your C450 with Aftermarket Wheels
Old 05-20-2016, 12:39 PM
  #176
SPONSOR
thewb's Avatar
www.wheelsboutique.com
HRE Has confirmed FlowForm fitments for the C450.
19"x8.5" +47 // 19"x9.5" +45
Front Wheel Requires 15mm Spacer for brake and lower arm clearance.
Please note that the 15mm spacer has only been seen on HRE's scan data - NOT actually fitting on a car.
If you want the best ff the best and at a price starting at just $625 per wheel then look no further. The HRE FF01 & FF15 are your answers.
Old 05-20-2016, 01:10 PM
  #177
lbowroom's Avatar
C450
Yep, that might work.
Old 05-20-2016, 01:45 PM
  #178
BRBM's Avatar
2016 C450
Originally Posted by BMWMB71
Väth C450!!!
Adjustable lowering springs 20 - 40mm, and 19" wheels 8,5" front and 9,5" rear.
I love it!
Originally Posted by thewb
You just made my knees buckle.
I wish we got this here in the States
My C450 ESTATE! The same black one I have, same night package with some additional stuff apparently blacked out! DAMMIT, MERCEDES!!
You ain't never lied, thwb. They need to stop screwing with us U.S. customers and let us special order damn thing. Irritates the hell outta me.........between tears.
Old 05-20-2016, 03:10 PM
  #179
NYCSoiL's Avatar
2018 GT R; Tesla M3P
Originally Posted by lbowroom
I'm sorry, but I just don't see how that's remotely possible since an 8.5 with a 34 offset needs a 3mm spacer to be comfortable.
"The offset is dependent on the hub dimensions and placement on the wheel, so comparing the offsets of two different types of wheels is an apples to oranges comparison."
Old 05-20-2016, 03:16 PM
  #180
alexasa's Avatar
c
This is simply not true.
Wheel width and offset is all you ever need to know to compare two wheels fitment against each other.
The offset is where the hub ends/starts.
Old 05-20-2016, 03:18 PM
  #181
SPONSOR
thewb's Avatar
I have made a correction to the post.
Old 05-20-2016, 03:30 PM
  #182
Mike5215's Avatar
2016 C300
The offset represents the distance from the centerline of the rim to the hub mounting surface. An 8" wide wheel has a centerline at 4". If the hub mounting surface was at 4", the wheel would have a zero offset.
The deviation from the centerline is the offset. A 35mm positive offset wheel has a hub mounting surface (back plate) that is 35mm away from the centerline, toward the front of the wheel.
A spacer lowers the effective offset by its thickness, as it relocates the hub mounting surface closer to the centerline. So if you use a 5mm spacer on a 35mm offset wheel, you've reduced the effective offset of the wheel to 30mm.
Decreasing the offset moves the wheel away from the strut and brakes on the back side, and closer to the fender lip on the front side.
Old 05-20-2016, 04:26 PM
  #183
lbowroom's Avatar
C450
OK, now that I believe! That's an 8.5" with a 32 offset.
Old 05-20-2016, 05:50 PM
  #184
2toneblown's Avatar
2016 C450
Still no 20" options tho?
Old 05-20-2016, 05:52 PM
  #185
SPONSOR
thewb's Avatar
Not just yet.
Old 05-20-2016, 07:15 PM
  #186
1stTimeBenz's Avatar
C450
Can anyone comment on whether the VMR710 ff with this spec would fit the C450?
VMR V710FF 19x8.5 ET35 9.5 5x112 ET33.
Would spacer be needed? Thanks.
Old 05-22-2016, 10:32 AM
  #187
NYCSoiL's Avatar
Old 05-23-2016, 12:16 AM
  #188
nadeau's Avatar
2016 C450
those look good!! what size and specs are they?
Old 05-23-2016, 12:14 PM
  #189
NYCSoiL's Avatar
Front: 19x8.5 +34 - 3mm spacer
Rear: 19x9.5 +50 - no spacer needed at all
BRIDGESTONE POTENZA S-04 POLE POSITION XL
225/40/19
265/35/19
nadeau (05-24-2016)
Old 05-26-2016, 06:08 PM
  #190
NYCSoiL's Avatar
Old 05-26-2016, 06:54 PM
  #191
lbowroom's Avatar
C450
That looks really good! Why were we thinking that an 8.5" was too wide on the front?
I see you went with a 225/265. Do you think a 245/275 would propose a problem with clearance?
Old 05-26-2016, 10:22 PM
  #192
NYCSoiL's Avatar
I think even 10.5 will fit in the back with no problem, but 8.5 in front maximum..
235 will fit perfectly on my rims, not sure about 245.
275 in the rear will fit, even 285 i think will fit
Old 05-29-2016, 09:17 PM
  #193
EuroGarage's Avatar
2016 Mercedes C450 AMG
The following 2 users liked this post by EuroGarage:
nadeau (05-31-2016), uptownman (06-16-2016)
Old 05-30-2016, 12:03 PM
  #194
Albanmtexas's Avatar
C450amg 2016
Go wide or go home.
Originally Posted by aimless
Good luck.
Old 05-30-2016, 12:17 PM
  #195
NYCSoiL's Avatar
Originally Posted by Albanmtexas
Wheels poke a lot...
Old 05-30-2016, 12:24 PM
  #196
C450amg 2016
Couldn't be happier!!! I want the aggressive look. If I wanted the stock look I would have never bought wheels.
Old 05-30-2016, 12:26 PM
  #197
NYCSoiL's Avatar
I get it, man, they look really nice! But never try driving on these in NYC lol... They are gonna rub a lot on every pothole
Old 05-30-2016, 12:31 PM
  #198
C450amg 2016
Bro these don't rub anywhere. Not sure why you think would. They tuck perfectly anytime they suspend. The suspension brings the wheel in at a camber where it doesn't rub. I had 285 on and they might rub on the inner liner of the fender which can be removed it's not needed. I went with a 275 instead. No rub no nothing bro car is getting lowered next week. Don't listen to the haters. This car drives like butter still.
Old 05-30-2016, 01:27 PM
  #199
aimless's Avatar
C450
You misunderstood me brooo.
I was saying they wouldn't fit. Not whether you could get them on your car or not.
Old 05-30-2016, 01:56 PM
  #200
C450amg 2016
I still don't understand what you mean. They wouldn't fit.
Quick Reply: Post your C450 with Aftermarket Wheels
