C63 AMG (W204) 2008 - 2015
Brake cooling ducts and modified front bumper
Old 08-29-2016, 05:20 PM
  #76
Bigtickets's Avatar
E55K, Black on Black. C63, Black on Black. SRT-10 NightRunner 363of400
Originally Posted by BLKROKT
Thanks for the idea. This is the correct link for our cars FYI:
https://hardbrakes.com/index.php?mai...MV948ln6umbd31
Jim, looks sharp. I'm waiting for your brake ducts.
Just ordered these as I've got another set of pads going on Thursday night. I will be at the track Friday afternoon thru Sunday. There are two thicknesses here and I opted for the thicker (1mm). I will let you know my thoughts.
BLKROKT (08-29-2016)
Old 08-29-2016, 06:30 PM
  #77
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Originally Posted by Jasonoff
The hood spacers work well for the S2000 platform, lowering both coolant, oil (if you have an external cooler) and IA temps. Unfortunately that's the only platform I have experience with.
I had a proper vented hood on mine (vent near the front) which did all 3 marginally better than the spacers.
Edit: not the best pic but this vent location worked very well.
Nice S2k.
On my RX-7 as I mentioned with the rear of the hood raised (stock) it didn't help IATs or water temps and with a string test they were pulled into the engine bay at highway speeds.
Going to a vented hood made a difference on water temps. I never got around to ducting the larger SMIC I had under the hood. With the vented hood when I did a string test the rear vents had noticeable less air lifting them than the more forward ones. But the hood definitely helped cool things off faster.
I always wanted to do a V-mount with the radiator and intercooler and proper ducting, but never got around to doing that before I started driving my Subaru more often and the RX-7 just sits and collects dust.
Attached Thumbnails Brake cooling ducts and modified front bumper-rx-7parked_zps602e6f58.jpg
Old 08-29-2016, 07:01 PM
  #78
Jasonoff's Avatar
Received 1,588 Likes on 936 Posts
2010 C63 AMG
Originally Posted by thesaintusa
Nice S2k.
Maybe it's something to do with how the engine is situated as well. Looks like there's more room for airflow under the S2000 hood.
My old girl
93 RX7
Attached Thumbnails Brake cooling ducts and modified front bumper-s2kscenginebay.jpg   Brake cooling ducts and modified front bumper-rx7enginebay5.jpg
Old 08-29-2016, 07:35 PM
  #79
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
Do a tuft/string test and see where the high/low pressure areas are located.
Velox Motorsports Hood Louver FRS BRZ Tuft Test
WTF is wickers?
Old 08-30-2016, 01:58 PM
  #80
BLKROKT's Avatar
Received 2,831 Likes on 1,673 Posts
Think I used jrcart's car to mock this one up LOL.
I'm not buying the concept that I need these to be louvers to extract the heat. Will start these out as BS/507-shaped holes with mesh beneath. If that doesn't work out, will replace the mesh with the BS/507 vents.
Old 08-30-2016, 06:02 PM
  #81
Bigtickets's Avatar
How are you thinking about trimming them out above the mesh at the actual metal of the hood?
Old 08-30-2016, 06:07 PM
  #82
BLKROKT's Avatar
I haven't gotten that far yet bud. I don't know, sand down the rough edge and paint it (my hood needs a respray badly)? Some sort of rubber weatherstripping?
Old 08-30-2016, 06:46 PM
  #83
Bigtickets's Avatar
Sand it smooth and repaint. I think it would look cleaner, especially with the mesh underneath. My .02
Speaking of repainting hoods, the whole nose of mine needs a respray. It's rashed up pretty good.
Old 08-30-2016, 06:48 PM
  #84
BLKROKT's Avatar
Yeah agree. Same - my front bumper is so pitted up. Once I get it all resprayed I'll get Xpel or something to protect it better.
Old 08-30-2016, 07:01 PM
  #85
Bigtickets's Avatar
That was the direction I was thinking about going. You know just as well as I do that eventually it will get through that as well. What's the process of removing films like that when it needs to be repainted again? Heat it up and peel it off, sand it off?
One of my bigger scratches is from one of B's rim bolts at VIR. At least that's my story.
Old 08-30-2016, 07:20 PM
  #86
BLKROKT's Avatar
I'm thinking maybe a matte black wrap would look nice. Probably cheaper than the hood, bumper and rear fenders I need paint on. And then some painters tape for the track so I can look like one of those idiots.
Old 02-01-2017, 12:42 PM
  #87
BLKROKT's Avatar
Velox Motorsports Hood Louver FRS BRZ Tuft Test - YouTube
Agree you want to let the air out rather than force it in.
You know, I could be wrong here, but looking at that picture again it looks like the louver flaps stick up into the airstream over the hood just a little bit. That should create low pressure areas behind each louver, allowing heat to extract through them. Right? Then that's the way to go, and placement isn't really relevant. They can go over the headers, or I should just measure the highest temp area under there. Hmm.
Old 02-01-2017, 02:17 PM
  #88
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Subscribed.
Old 02-01-2017, 03:30 PM
  #89
C SEXY 3's Avatar
2006 E350 (SOLD), 2010 C63 AMG
BLKROKT, where are you at with this? I semi-skimmed the thread but didn't see if you started cutting or not.
Old 02-07-2017, 07:35 PM
  #90
Cli63's Avatar
2012 c63
Hey BLKROKT, where did you get the mesh you replaced the grills with? Considering doing this mod when I get my 440 on.
Old 02-07-2017, 07:51 PM
  #91
BLKROKT's Avatar
http://www.customcargrills.com/Hexagon-Grill-Mesh.asp
Old 02-07-2017, 07:58 PM
  #92
Cli63's Avatar
2012 c63
Did you just get 2 sheets of 16x48?
Old 02-07-2017, 08:23 PM
  #93
BLKROKT's Avatar
I got like 4 16x48 sheets of this (http://www.customcargrills.com/Hexagon-Grill-Mesh.asp - I used the flat black 77% open stuff) because I figured that I'll ding them up at the track and just replace them when they start to look ratty. Plus I got some extra in case I wanted to trim out my diffuser or holes in my hood. Bought some tin snips and just cut them to size with about 1" extra all around. You'll want to bend and shape the edges over a wood block - it takes time to get it right. I found some good DIYs online, one was on Rennlist I believe.
Also, the hot glue sticks didn't hold the mesh up for long. When Harry at Bergen installed the 44O kit, he reattached the mesh using some sort of bumper epoxy Bondo-like stuff. So far so good.
Old 02-08-2017, 10:22 AM
  #94
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
You could use some polyurethane but it'll be a pita to get off.
You know how on prefacelift, the slots in the rear taillights are for aerodynamics? I was looking at our chrysler 300 and it has some slits near the bottom back of the wheel arches. Maybe that could help with some stability (not necessarily cooling brakes) but using the airflow to keep the car grounded. Not sure what they did with the slits in the facelift version.
Old 02-08-2017, 11:03 AM
  #95
BLKROKT's Avatar
You mean these?
AFAIK it lets the air from the spinning tires exit the wheel wells more efficiently and creates some downforce. The BS has them in front also.
I just bought some new power tools and some sheet aluminum so I can make some front flics for starters. I might also take my Dremel to the rear bumper at some point, as with the increased fender and bumper width I could probably pull those off.
Old 02-08-2017, 01:04 PM
  #96
Adi-Benz's Avatar
You mean these?
Pretty much yea. The chrysler might have them for a different reason as they are on the inside of the wheel arches but there is no exit straight through the rear bumper, as it goes down under I think.
Pretty bold cutting up this stuff lol. I'd be afraid I'd screw it up haha.
Old 02-08-2017, 06:50 PM
  #97
zcct04's Avatar
http://jalopnik.com/the-cadillac-ats...-of-1787045357
This is an interesting discussion about cooling on the ATS-V. Sounds in places like the 440 package. Explanation down towards the end about the Caddy's hood heat extractors is relevant to this thread's discussion about engine compartment vents.
BLKROKT (02-08-2017)
Old 02-08-2017, 07:37 PM
  #98
BLKROKT's Avatar
That was an excellent article and there are lots of ideas there applicable to this thread - hood hole, how that horizontal cooler works (on my car it's the oil cooler for the 44O kit), the rear diff cooler plumbing, and the brake ducts. This is where basically where my car is going word-for-word. Still trying to figure out the hood holes though this is giving me another idea thanks....
Old 02-08-2017, 08:24 PM
  #99
Diabolis's Avatar
You mean these?
FWIW, I don't think those (or the ones on the front) on the C63 BS are actually functional. I really hope I am wrong... can someone confirm? Are they actually open or blocked and just look like vents?
Old 02-08-2017, 08:31 PM
  #100
BLKROKT's Avatar
The ones in the FL front bumper are blocked and just decorative, so I assume those are as well. Someone should Dremel those open.
Quick Reply: Brake cooling ducts and modified front bumper
