all the dyno info is on the sheet bud.no correction factor added.temp, humidity,baro
437whp is exactly what a healthy p31 should be at with row boxes and afe filters and 93oct tune.
But you are leaving out a VERY important component, the BRAND of dyno you are running on is pretty well known to give considerably higher numbers than other dyno types....Take mine for example, I'm ROW, aFe and tune as well...Strong as hell BUT my pulls are all on a DynoDynamics and run within 3hp/tq of 389 back to back to back....That is run what you brung, no correction, no smoothing, DD hurt your feelings numbers ....Would my car pull 389 on a Mustang? I'm positive it wouldn't but would my engine be any stronger/weaker because of the dyno numbers printed out by different brands? Nope....So the only even remotely way possible to gauge dyno numbers from car to car would be to run them on the same dyno....Other than that it is apples and chinchillas
my numbers are not high or unusual for dynojet numbers and most dyno dynamics or mustang dynos are not run in shootout mode and are configured and corrected to read like dynojets.
my before and after was done on the same dyno and the last few cars that were posted here used dynojets. all the info is there and there is nothing to hide. same gas,same gear same uncorrected runs vs tune vs row/filters.
I was expecting 445whp and will load the 104 oct map and run race gas and see what she does.jeremy told me it will pick up 10-15whp on 104 tune file and my car was so smooth on the dyno that smoothing set to zero was smoother then my stock tune on 5
Dude, did you go off your meds? You are acting like I called bull**** on you....I don't doubt that your numbers are what they are, on THAT dyno...do you honestly think you'd pull the same numbers on a different unit? Dynos are good for setting baselines and then monitoring your gains as you progress through different iterations of your car....other than that a track and a stopwatch are the true yardsticks to where you really stand....I was just pointing out that they all read different, hell even the same dyno can read different on the same car on the same day if a different operator sets up the runs and the modes.....the apples to chinchillas comment was not about YOUR numbers compared to YOUR numbers either, it was in relation to people, yourself included, trying to correlate other peoples engine's output using different dynomometers on different days in different locations on different machines with different DAs....your numbers are good for one beneficiary, YOU....I wasn't trying to inflict any butthurtedness on you,
My numbers are UNCORRECTED no cf the operator did not apply any CF this is what my car put down today with my temps and baro pressure and conditions without the software adding any numbers like the other thread with 451hp but used a 1.03 correction factor so the dyno software multiplyed his numbers by 1.03 to give him a higher reading to compensate for the high humidity.
you are calling out a dynojet that used no correction factor.ive seen heartbreaker dynos read higher than dynojets and same with mustang dynos.
it's crazy how some people hate on dynojets.i can see you saying your dyno is good for seeing gains on the car if it read crazy high like 456 whp and had a base line to use with a higher reading dyno but man my sheet is uncorrected.
it's what the car made this day like how the car would run down the 1/4 mile.you don't have your time slip spit you out a std corrected pass as if the weather was better lol
it's pretty easy to manipulate any dyno numbers.if I wanted to we could of put a heat gun at the dyno temp sensor and had the dyno add 1.04 correction factor then posted a sheet of my SAE or std corrected numbers but hide the run details like what the actual correction factor was and the temp and humidity and baro on the bottom of the dyno sheet. then said hey my car made 456whp etc and just posted the numbers SAE without showing the full details.
I have a before tune dyno with row boxes,pro drys and stock tune on 93oct and it made 399whp.
Very good numbers. My stock p31 with ROW boxes and AFE dry filters also dynoed 402whp on a dynojet. With V5 tune, I got 419whp and 383 ft-lbs. I posted my dyno in this thread: https://mbworld.org/forums/c63-amg-w...olde-dyno.html
thanks man and yea I just saw it.how many miles do you have on your spark plugs and what gas do you guys have there.i think you have some lower left on the table
