Looking for an addition ~30rwhp upgrade. I'm looking into 82mm TB or changing my pulley from 77mm to 70mm. Both of this will achieve my goal.
The question now is which of this mods will be cost effective, and less problematic, and why? List of current mods is in my sig.
Throttlebody is our personal favorite mod. 35whp and great throttle response. we have both 82 and 85mm kits available, with and without a pre ported snout.
Our throttlebody kits are currently onsale and you can see all of the options ->Here<-
I would consider injectors before adding another power mod also.
You cant potentially ruin a USED TB by milling the mounting holes. Way cheaper since used 82mm TB units sell for $150 on ebay and 20 mins with a dremel tool and you can port your OEM 74mm snout.
It is also worth mentioning the TB will be oriented the same way and not clocked at the different position when you use the "BOLT ON" flange. Air boxes will secure in the same location because of the absence of the adapter flange moving everything back.
Rotation of the Throttlebody does not effect performance
Airboxes still fit perfectly with the less than 1/4" adapter in place
The adapter can act as a stencil for you to port your snout,
The most effective way, other than CnC porting (thats what we do) Is to use a flap wheel sander and a drill. If you dont feel comfortable with porting it yourself we do offer the Porting service independent of the parts we sell.
I offered a solution with OEM fitment and at lower price point.
There are many ways to skin this cat or in this case, throttle body upgrade... When I want shiny parts I will visit VRP as they have many to offer, until then I will be doing things myself with used parts. Thanks for the alternative solution Shardul
+1 for more fuel then upgrade your Throttle Body unless your tuner agrees it is safe to add more air only
If you go 550cc's DO NOT get them from ebay unless you want to swap them 3 times, I just had a bad experience with a set from there that's my $0.02
Hey Tony.
What about the good ole "hiccup" complaint's many people have? No issue's ?
Hey Tony.
No one but the german tuners have solved it so far. Its a shame IMHO.
You hear reports about that issue all over the place, forums, Facebook groups, etc.
Many of the newer users dont even know about that well known issue - they just say it like "Sometimes on part throttle my car goes suddennly very lean, but a key cycle will solve it"... lol
Hey Tony.
^ And that's what have been holding me back so far in the purchase of the TB. So I'm thinking about going the 70mm sc pulley route instead. But there're less info about that, so I am stuck in between decision making.
