Cracked Rim - Now Slow Leak
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
Happened to me this morning on the way to a conference. It hit a large pothole which I didn't see due to sun glare. Luckily I was near a gas station to fill it up with air. But PSI reader came up red. It went from 33 to 14. I filled it back up to 33 and by the time I got home (2 miles or so) it was back down to 26.
Insurance covers it so adjuster is on his way out. I have the AMG rims. If they can't repair it I guess I'll be forced to replace the whole set. Any reasonable staggered set of rims for my E550? I'd like to stay under a grand for the entire set if possible.
2012 E350 sedan
I expect that the adjuster will total the rim and pay you for a new one. That is what happened to me the last time I crunched a rim 10 years ago on another car. So why would you feel forced to get a new set of 4? There are rim repair shops in all major cities that should be able to fix it. Typical cost is around $150.
In my case, I did not like my OEM wheels and used the money to buy an aftermarket set. The OEM rim was so expensive that the OEM price of one wheel nearly paid for my aftermarket set of 4. I had the crunched rim repaired and sold the OEM set on eBay. (I was upfront that one rim had been repaired.) I used the shipping boxes from the aftermarket set to ship the OEM rims. So I would up with rims I liked and was several hundred $ ahead.
However, I love my AMG rims so if I were in your shoes, I'd keep them. Get the crunched rim repaired and keep it as a spare.
On a similar topic, I follow several BMW and Audi forums too and I have seen far more bent rim posts on this board than all the other boards combined. These rims must really be soft.
If you follow the BMW forum, you must see a whole bunch of bent rims on there. If you stare at the BMW rims long enough, you will cause a bent. This is due to the combination of runflat tires and BMW's light weight rims. I had 3 bent rims in the BMWs I have owned in the pass and, cross my finger, none so far in my Mercedes. Driving in NY and NJ, bent rims are pretty much the cost of doing business. The roads are like a war zone out there.
Only reason I'd prefer a new set is all 4 have curb rash. It's been like that since I purchased the vehicle so I was leaning towards a new set possibly. If they can just repair it then I'm cool with that. My deductible is 1k and I doubt even a replacement of the AMG rim is that much. So if I have to come out of pocket might as well get a new set. I read somewhere these rims are like 800 new for one but I'm not sure if that.
2010 e550 p2
lol yep pretty pricey for a wheel... even ADV 1 dont cost that much jk jk , they cost a lot more... but still
post up a picture if you can , i can tell you if its better to repair or get a new one.. if you want
Only visual damage is the bent out lip and it has 2 small cracks/slices in it. A repair seems possible but not sure of how it usually works.
Looks like alloy and that can be repaired, I've had a few done. Get yourself some new center caps on ebay too. Good luck
jahquan3 (03-24-2017)
Received 1,506 Likes
2008 E350 4Matic, 2011 E350 4matic
You can also get the curb rash cleaned up, about the same price anywhere from $100-$150 a wheel. It's probably cheaper if you do all 4. Not a fan of aftermarket wheels, especially if you're going to get a cheap set. I had one rim fixed and the guy had a bunch of aftermarket rims sitting around that he couldn't fix, they just tend to crack instead of bend.
2010 e550 p2
I know a guy that can fix it , for about 80(just the repair no touch up paint) but looks like u not in cali... so im guessing for 150 a shop can do both? And yes it is fixable , i had worse lol
and here are the 2 colors in pics
Thanks for the help everyone.
Adjustor just called and said he thinks I need a whole new rim and tire. He thinks I also need to get it on a lift to get a closer inspection at the control arm etc.
He says the rim is $1400 (From Mercedes) and he has the tire at $40.
I guess that's a random tire price since even though the Yokohama ADV Sport are inexpensive they cost me about 150-175 per wheel if I recall correctly.
Edit: I received estimate documents by e-mail just now. See breakdown:
$1,410 Wheel/Rim - 1
$340.99 Tire - 1
$69.95 Suspension Alignment
$13.50 Mount Balance and Misc Fees
$14.70 Body Labor ??? (Never heard of this)
$122.32 Sales Tax
$1971.46 - Total
$340.99 Tire - 1
$122.32 Sales Tax
$1971.46 - Total
Last edited by jahquan3; 03-24-2017 at 11:54 AM. Reason: Actual estimate came in e-mail
2010 e550 p2
so if your deduct. is 1k is it really worth it?
can easy get a tire and a wheel for less even with alignment included
(when i had mine repaired i checked out ebay and there was a used one for 250 with the tire on it (and thats if you dont want to repair your current one which i would and it still be even cheaper))
total is crazy
p.s unless there is a damage to control arms or sway links ..etc.
and yet it still be less than a grand
total is crazy
I'm definitely leaning towards just getting a new set of rims. Even if I have to spend over a grand there is no way I'd pay that much for one wheel and still have the rest looking subpar.
I still have a warranty I believe on the tire so I should be able to purchase another and get reimbursed from Tire Rack.
I might still see if I can get it repaired but at this point I don't want to deal with the headache. I have a couple days to decide since GEICO can't get the car towed until Monday the earliest they said.
FYI - The gave me and rental Elantra and it started making some loud **** noises as if something in the under carriage got loose. So they brought me a Chevy Cruze just an hour or so ago. My luck with cars is looking dim right now LMAO
For a $1000, I would go for a new set of rims, those OEM rims are way over priced. Once the repair guy heats up the rim and bent it back, it will not be as hard as before, the next pothole you hit, you might have to go thru this insurance mess all over again.
2010 e550 p2
Can you just pocket the difference? I think you can just have them send you the check instead of sending it to an auto body shop. I'd just get another rim on eBay and get the old one fixed just in case.
http://www.ebay.com/itm/2010-Mercede...dYzQN4&vxp=mtr
http://www.ebay.com/itm/OEM-Factory-...hYm0lk&vxp=mtr
Personally I hate aftermarket wheels, they never quite look right and I tend to avoid any used car with aftermarket wheels.
