GLK Owners With Dreaded Command Dial Failure?
Old Feb 24, 2015 | 05:16 PM
chuckmahon's Avatar
GLK 350 2010
Hello fellow GLK Owners!
Wanted to ask if anyone else has encountered the dreaded Command Dial / Wheel failure that is so well documented in the C Class community. (see link below)
If so - and since it is so prolific, is there any hope of MB replacing this in an out of warranty vehicle? Recall? Service bulletin of some kind? Seems like this part will fail every 4 years like clockwork.
Thanks!
Chuck
e.g. https://mbworld.org/forums/e-class-w...trol-knob.html
Old Feb 25, 2015 | 09:10 AM
bop11's Avatar
350 GLK, C280
My 2010 (built end of 2009) is still without problem. Doubt MB will repair after warranty if it goes bad. Has yours failed?
Old Feb 25, 2015 | 09:20 AM
chuckmahon's Avatar
GLK 350 2010
Mine failed a few weeks ago - right at 4 year mark! Uncanny!
Any insights to removing whole assembly from the GLK console? Is it similar to E/C Class?
Old Feb 26, 2015 | 03:13 PM
bop11's Avatar
350 GLK, C280
probably exactly the same as C class.
Old Feb 28, 2015 | 01:29 PM
NYCGLK's Avatar
GLK 350 / Porsche 993
i had my screen die a while back (still under warranty). Never had problem with idrive.
Old Jul 28, 2016 | 09:35 PM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
Nevermind, found it
Old Aug 4, 2016 | 07:48 PM
TSchuettinger's Avatar
2016 volkswagen beetle
It's weird to hear about this on anything else than the C class. What's funny is, the command knob problem dosent show up in consumer reports, nor do people bring it up on consumer reviews on edmunds, kbb, cars.com ect...
Old Apr 17, 2017 | 01:24 PM
AzCamel's Avatar
Seems like mine just died after I updated the nav system. Bought the replacement aluminum shaft, hopefully this is the issue
Old Apr 17, 2017 | 01:27 PM
chuckmahon's Avatar
GLK 350 2010
wait, there is a replacement *aluminum* shaft? Where did you get it? How installed?
thanks!
Old Apr 17, 2017 | 01:31 PM
AzCamel's Avatar
thanks!
eBay. It was 30 bucks. I should get it Friday and will attempt to fix it Saturday evening
Old Apr 17, 2017 | 01:37 PM
chuckmahon's Avatar
GLK 350 2010
Share a link - please!!!
Old Apr 17, 2017 | 02:19 PM
AzCamel's Avatar
IE Works Replacement Shaft for Mercedes Console Command Controller Knob Multi-Switch Push-Button Assembly Repair
Old Apr 20, 2017 | 09:55 PM
AzCamel's Avatar
The part came in and it is quality, fits perfectly and most importantly I got my scroll function back!.
notes:
There are 10 screws on the back, some of then recessed deep and I couldn't get to it with my torx, u used an Allen that fit and removed it carefully.
I also managed to remove the unit without cutting the wires likes other did, follow the wire, it is held to the consol by a clip that you must pull the carpet back to reach, then unclip it.
Old Apr 21, 2017 | 10:30 AM
B737's Avatar
2012 GLK
nice job AZ, i ordered this piece to have on hand...
Old Dec 5, 2018 | 08:48 PM
Dbcloudstrife1's Avatar
Mercedes glk 350 4matic
Getting started
Hello,
I have a 2011 glk350 4matic. I want to change the aluminum shaft but I am having trouble getting started and removing the console.i have spent alot of time searching online and looking around the console myself. So far, I have removed the back of the console and 3 screws, 2 on the back and 1 under the little rubber compartment. I have the step by step instructions once I get it open. Can anyone help me past this point?
Old Dec 5, 2018 | 11:40 PM
Mystic2k's Avatar
2011 GLK 350
You can refer to this video "https://www.youtube.com/watch?v=gU5NB7jpqOM".
I just replaced mine with aluminum shaft a month ago.
Good luck!
Old Dec 6, 2018 | 05:35 AM
Getting started
Good luck!
Thanks for sending. I have seen this video and the console is different than the glk so it did not help me.. I wanted to see exactly how to remove the screws etc on the glk console and how to get it off without breaking.
Old Dec 15, 2018 | 01:26 PM
Mystic2k's Avatar
2011 GLK 350
The video C class is very identical to GLK except it's right hand drive vs left hand drive.
I put a short instruction to remove the shifter cover. Hopefully it helps.
File Type: pdf
Old Dec 15, 2018 | 02:13 PM
Wow, I think this is exactly what I was looking for. I will go take a look and see if I can make some progress. Thanks so much for taking the time to share.
Old Mar 23, 2019 | 01:53 AM
webada's Avatar
528i, GLK
Mine just broke after almost 10 years. 2010 GLK here. Have order the parts necessary. any tips on the disconnecting the cable?
Wish me luck!
Old Apr 5, 2019 | 01:38 AM
Mystic2k's Avatar
2011 GLK 350
I didn't disconnect any cable. So it didn't have much room to move around the module. But I got it changed.
