C450/C43 AMG
wheel spacers for c450 amg?
Old Apr 29, 2017 | 08:34 PM
ragebkd's Avatar
2016 C450
Does anyone have any recommendation for front wheel spacers for the c450 amg? I believe I need 10mm
Thanks,
Old Apr 30, 2017 | 10:25 PM
alexasa's Avatar
c
15 is too much on stock wheels unless you have lowered the car.
I put a set of 5 on there and was content.
10 do not work due to the hub design (unless custom made). so go for 5's or 15+.
Old May 2, 2017 | 12:31 PM
c_sotelo5's Avatar
Mercedes C450 AMG
10mm front, 15mm rear.. by ECS Tuning
Attached Thumbnails wheel spacers for c450 amg?-photo661.jpg   wheel spacers for c450 amg?-photo121.jpg
Old May 2, 2017 | 12:32 PM
c_sotelo5's Avatar
Mercedes C450 AMG
PS, Its lowered on H&R Sport Springs
Old May 2, 2017 | 05:53 PM
ragebkd's Avatar
2016 C450
That looks like what I need. Can you link me to where you bought them or give me the exact model info?
Thanks!
Old May 2, 2017 | 06:23 PM
c_sotelo5's Avatar
Mercedes C450 AMG
Here you go man
10mm Spacer:
https://www.ecstuning.com/b-ecs-part...411ecs02a10kt/
Bolts for 10mm spacer:
https://www.ecstuning.com/b-ecs-part...d40-znnitt~ec/
Old May 2, 2017 | 07:40 PM
alexasa's Avatar
c
there is no way that 10mm spacer works correctly (not on the 19 inch wheels). I have those spacers and they do sit flush with the hub. Please verify that you are not putting yourself in danger and those are mounted correctly.
Old May 2, 2017 | 07:59 PM
c_sotelo5's Avatar
Mercedes C450 AMG
I have the 18" wheels
Old May 2, 2017 | 08:03 PM
c_sotelo5's Avatar
Mercedes C450 AMG
Fitment was also verified by ECS via VIN#
Also had MB replace my brakes and rotors and there was no problem with fitment using these spacer @ front or rear
Old May 2, 2017 | 08:17 PM
alexasa's Avatar
c
they may work on the 18 wheel but they DID NOT on the 19 inch multispoke wheels.
I tried both 10mm (same part number) and 12mm and neither work due to the design of the hub.
Other people have verified on c450's and c63's that 15mm spacer is the required size to fit properly (unless custom spacers). I would definitely double check.
Old May 2, 2017 | 09:23 PM
c_sotelo5's Avatar
Mercedes C450 AMG
I am using 15mm in the rear and also like I've said double checked.
Old May 2, 2017 | 10:16 PM
atl 2 chi's Avatar
Current :2018 E63S and a 2018 GLE 63S . Prior, CLA 250, C450, 2017 AMG C63S
Front: Vossen VFS-2 20x8.5 with 13 mm Spacer to get me at ET +31
Rear: Vossen VFS-2 20x10 ET 55 (no spacer)
And my vehicle is lowered on H&R Springs
Old May 3, 2017 | 05:57 AM
alexasa's Avatar
c
https://mbworld.org/forums/c63-c63s-...acers-fit.html
this is the problem with smaller spacers (non-custom)
if they do have the sleeve extended, like the 10's you've posted, then it will fit the hub but not sit flush with the rear mounting surface of the wheel.
Old May 3, 2017 | 09:46 AM
c_sotelo5's Avatar
Mercedes C450 AMG
I saw someone here post they used 8 all around, worse come to worse I'll run 8s in the front
Old May 3, 2017 | 01:15 PM
DVision44's Avatar
c43 Amg coupe
This is the issue i had with my coupe. Had to return the 10's and go 15 all around.
Old May 3, 2017 | 01:27 PM
lak2881's Avatar
C 43
So if you have 19 inch wheels 5mm or 15mm are the only options? I dont plan on lowering my car and imagine 15mm might look a bit much if im not lowering and 5mm prob hardly makes a difference. Anyone with pics of stock 19's with 5mm spacers?
Old May 3, 2017 | 01:48 PM
alexasa's Avatar
c
I ran 5/15 f/r on the stock wheels. rear is a hair too much with those specs.
I also ran 8's for a short time. Those require a wheel hanger, etc. to get a proper mount - but should would (I wouldn't recommend it).
Old May 5, 2017 | 09:35 PM
sean1.8t's Avatar
c-fo-fiddy
Need some help on rear wheel fitment.
I know for a front 8.5" wheel I need the ET to be around 30. but I'm not sure on the rear.
Have a wheel that is 19x9.5 ET45
Is that going to work? Will I need a spacer?
Thank you in advance!
Old May 6, 2017 | 08:34 AM
alexasa's Avatar
c
should be perfectly flush with a 275, you'll have a little bit of play with less tire.
Old May 6, 2017 | 10:57 AM
sean1.8t's Avatar
c-fo-fiddy
Awesome! So no spacer is needed?
Sorry, I just like to double and triple check these sort of things
Old May 6, 2017 | 11:06 AM
alexasa's Avatar
c
No. I am running 9.5 et 48 (have a smedge of room left to push the tire out.
It will be at it's maximum offset at OE suspension height with a 275, but will look great if that's the look you are going for.
Old May 6, 2017 | 11:57 AM
sean1.8t's Avatar
c-fo-fiddy
Oh good call, I wasn't thinking about that. H&R springs are going on with them so maybe I should tick them down to 265s just to be safe?
Old May 6, 2017 | 12:09 PM
sean1.8t's Avatar
c-fo-fiddy
So the front wheels I have coming are 8.5's w/ a 40et. Was just going to run a 10mm spacer and be done with it but now that I've actually read this thread, that seems like a bit of a challenge? I'm very confused here. Anyone help? Also, going to be on H&R springs with 235/35 tires if that makes any difference or helps
Old May 6, 2017 | 03:35 PM
alexasa's Avatar
c
depends on wheel. If they are bored to 66.6 without hubrings etc. you will run into the same problem with the 10mm spacers as people have with the stock wheels. 8mm non hub-centric spacers will work but you will have to fight vibrations and ensure mounting is perfect because it won't much of any hub to sit on (I wouldn't recommend it).
235/40 would be a more appropriate tire size. and I would recommend a 265/35 for the rear on H&R's at that offset.
That way you can keep the rolling diameter the same between the front and rear and be closer to stock than a 235/35 would be.
It sounds like you need to re-evaluate the front wheels.
Old May 6, 2017 | 03:44 PM
sean1.8t's Avatar
c-fo-fiddy
Re-evaluate? As in get different wheels? Too late for that as they are on their way...
There's got to be another way to fit them. Bore out the hub or spacer to make them mate flush?
