No spacers fit
- The ECS Tuning spacers had the incorrect chamfer on the front of the spacer resulting in the spacer not sitting flush with the rear of the wheel hub. (10mm)
- The H&R spacers had the same problem as the ECS Tuning spacers. (12mm)
- And the Supreme Power spacers (which others are running on the C63) do not seat to the OE hub because the inner bore of the spacer steps down too soon. (12mm)
The last thing I am willing to try are the burger motorsports spacers.
I know some people have bought ebay spacers or paid way too much money for custom spacers for the car - but I will not entertain either of those options.
Just some info for those c43 guys (and I would think it would also apply to the c63 guys). Now, if I were to run the 15mm spacers from supreme power, I am thinking they would work.
So, I would say 3-8mm spacers work.
and 15mm+ spacers work.
But nothing in between. (only applies to buying spacers off the shelf.)
A lowered car with a bit of natural camber, 15mm would work. But, I'm not planning on lowering the car as of now.
https://www.ecstuning.com/b-h-and-r-.../3055665sw~hr/
I had my car lowered with 295s with 10mm spacers in the rear. It fit perfectly and there was no rubbing whatsoever. That's how the car should have come standard. You can even do 12mm and pull it off with out rubbing.
I'm not sure who advised against it but I can bet they are people who haven't even tried it. I can personally say no issues.
Please see my car when it was lowered with 295s - 10mm spacer rears and 20mm fronts.
Front shot
Side shot
Why are you on probation bro? Who did you **** off
