GL Class (X164) 2007-2012: GL320CDI, GL420CDI, GL450, GL550
2012 GL350, trying to activate sat radio, and no sound, won't activate?
Old 04-24-2017, 06:58 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Sound is good on ALL other sources. Sat radio will only show channel 184 preview channel, no sound on 184, and Sirius says they sent signal twice. What's the trick? This is dumb if it has to go to dealer for a simple sat setup on a new account.
Old 04-24-2017, 09:49 PM
gl450x164's Avatar
gl450 530i
i unplugged mine and plugged it back in. ..fixed my problem
Old 04-24-2017, 10:20 PM
Jason B's Avatar
Unplugged what?
Old 04-24-2017, 10:23 PM
gl450x164's Avatar
gl450 530i
the receiver...drivers side under passenger seat
Old 04-24-2017, 10:27 PM
Jason B's Avatar
oh wow. Had no idea it was there!! I should try that next.
Old 04-25-2017, 10:36 AM
Jason B's Avatar
wait. Did you mistype? Which seat is it under?
Old 04-25-2017, 01:55 PM
gl450x164's Avatar
gl450 530i
under the passenger seat behind the drivers seat
Old 04-25-2017, 03:05 PM
Jason B's Avatar
OK I found out how to open the rear seat to find the sat module and I unplugged it and re-plugged in. Now, the fan comes on after I plug it back in, only for like 5 sec, and then turns off. Can you tell me if your fan is on all the time when radio is ON?? And what year is yours.
Same issue. Is there a certain sequence you did? Since this is new to me, I can't remember if it always did this or used to have sound on the preview Channel, but trying to set up new service and can't get past this portion.
Old 04-25-2017, 09:29 PM
gl450x164's Avatar
gl450 530i
mine is an 07 so i have a different command unit but i used had them resend the signal after and works like a charm been two years now
Old 04-26-2017, 02:50 PM
konigstiger's Avatar
Received 4,435 Likes on 3,152 Posts
'71 Pinto
Try disconnecting battery for a few minutes to attempt a system reset. If this fails module “may” need replacement - MB DAS for definitive diagnose.
Old 04-28-2017, 10:52 AM
Jason B's Avatar
After sitting for a day the preview channel finally had sound while driving. Had Sirius sent the signal again, then it connected.
But, it's sporadic. It will play then will cut out and say no service randomly. Antenna or module?
Old 04-28-2017, 11:45 AM
gl450x164's Avatar
gl450 530i
dont you have star Jason?
Old 05-04-2017, 06:13 PM
Jason B's Avatar
Had it in for something else and it looks like is antenna. $800 labor to put new antenna harness in. Any other options? Aftermarket antenna?
Old 05-15-2017, 01:47 PM
Jason B's Avatar
Are there there any aftermarket antennas for sat radio that can be mounted inside? Don't want to deal with ripping down headliner to fix factory antenna that seems to be a known issue to break.
Quick Reply: 2012 GL350, trying to activate sat radio, and no sound, won't activate?
