2012 GL350, trying to activate sat radio, and no sound, won't activate?
Sound is good on ALL other sources. Sat radio will only show channel 184 preview channel, no sound on 184, and Sirius says they sent signal twice. What's the trick? This is dumb if it has to go to dealer for a simple sat setup on a new account.
Same issue. Is there a certain sequence you did? Since this is new to me, I can't remember if it always did this or used to have sound on the preview Channel, but trying to set up new service and can't get past this portion.
mine is an 07 so i have a different command unit but i used had them resend the signal after and works like a charm been two years now
After sitting for a day the preview channel finally had sound while driving. Had Sirius sent the signal again, then it connected.
But, it's sporadic. It will play then will cut out and say no service randomly. Antenna or module?
