how do you replace this?
Old Mar 31, 2017 | 04:42 PM
PJmak's Avatar
Rear vontrol arm mount(front by the wheel)
Its torn as a mother. It can rotate like aballjoint would. Dont see a way top it out.
Attached Thumbnails how do you replace this?-20170331_133628.jpg   how do you replace this?-20170331_133615.jpg
Old Apr 1, 2017 | 06:43 AM
W202AMG's Avatar
W202 C43 1999
Is it sloppy? It IS like a ball joint. It is meant to move on angles.
Old Apr 1, 2017 | 11:33 AM
PJmak's Avatar
Its not sloppy and yes its supposed to move like a balljoint but the seals are completely done. I wanna teplace it while im down there
Old Apr 1, 2017 | 12:13 PM
cm60k's Avatar
This is "W124/W140/R129/R170/W201/W202/W208/W210" rear hub bushing, can be removed by basic Extractor puller:-
http://www.peachparts.com/shopforum/...-question.html
http://www.peachparts.com/shopforum/...24-others.html
-;ZAYED;-
Old Apr 1, 2017 | 01:14 PM
mickey13's Avatar
1999 AMG C43
damn bro!
Old Apr 2, 2017 | 04:09 AM
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
The DIY link (second) is a great writeup
The Peachpart forum is also a great place for info
Old Apr 2, 2017 | 06:01 AM
W202AMG's Avatar
W202 C43 1999
If those in my 95 C180 were still fine after 22 years and 366,500klms, i wouldnt bother touching them til theyre needing it.
Old Apr 2, 2017 | 02:22 PM
PJmak's Avatar
Thanks guys. I found someone with the tool. The bushings are cheap and Im replacing the shocks in the rear so I might as well do it
Old Apr 19, 2017 | 11:17 AM
PJmak's Avatar
So my friend ended up not being able to find the tool and my car has been on jack stands for weeks now.
I managed to pop out one of the old bushings but I ruined two brand new ones trying to put them in :\
This is kinda frustrating. Theres no way in hell im gonna buy a
$150 tool just to use it one time. I really dont know when ill have to use that tool again.
I made a DIY tool and my biggest challenge is when putting the new bushing back in, its hard to make it go in completely straight.
Old Apr 19, 2017 | 11:36 AM
DRBC43AMG's Avatar
Is the arm hole clean and edges free of any sharp edges? Try using a fine metal file to round out a bit the edges of the hole. I would also oil or grease with a fine film to help ease the bush in. I used my workshop vice to press in the bush in my Ultima wishbones.
Oups just realized that the bush is on the axle carrier and no way can you get a vice in situ up there
Old Apr 19, 2017 | 12:58 PM
KJI3jflarryfe93's Avatar
this is the bush that sits behind the rotor dust cover on rear axel
Old Apr 20, 2017 | 07:06 AM
W202AMG's Avatar
W202 C43 1999
Hmmm... There was a reason i said if theyre not buggered, dont touch them...
Old Apr 20, 2017 | 10:35 AM
PJmak's Avatar
They were pretty rough shape and had a little play in them. The seals were done and the grease inside was almost all gone, exposing the layer of plastic that the ball sits in and drying it out.
Old Apr 20, 2017 | 11:03 AM
DRBC43AMG's Avatar
Guess that's a sufficient reason to change...
Old Apr 22, 2017 | 11:40 AM
svt ricco's Avatar
1999 C43 AMG
Off topic... pj I've been trying to text you. If you changed your number, please pm me. Thanks
Old Apr 23, 2017 | 04:04 AM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
With the tool they go right in, have done MANY
Old Apr 23, 2017 | 09:11 PM
PJmak's Avatar
I was able to get the driver side in now that I came up with my own tool. Went in pretty smoothly.
Ricco I PMed you. I never got any calls from you bro...
Old May 11, 2017 | 11:45 PM
JohnnyRock's Avatar
1998 C43 AMG
I feel weird asking another guy this, but can you show us your homemade tool?
Old May 12, 2017 | 02:18 PM
PJ did your bushes feel saggy when you squeezed the rubber edges?
if they feel soft olio had leaked out making bush sound squeeky like a flat tire or thump thump noise
Old May 12, 2017 | 03:39 PM
Pagz's Avatar
C43 w/clk55 Organs
I don't think I've owned a 202 yet where these are not split!, they would last forever if no dust got in there. good idea to replace if your in that area,if they have play it will make the rear end feel much more planted.
Diy tool is pretty straight forward you'll need a high tensile M12x120 cap bolt and nut or similar. suitable thick wall(~3mm+) tube 42mmID for the outer tube and 38mmOD ~2mm wall for the inner tube. super thick washers ~10mm. Good lube. as can be seen in the photo one portion of the pipe needs to be shaped to the axle carrier as this is not a flat surface to pull against, some care has to be taken otherswise it will deform your puller. If your short on time $150 doesn't sound that bad.
Cheers
Old May 12, 2017 | 03:56 PM
PJmak's Avatar
Whatever you do, for your bolts and nuts get grade 8 steel. Other stuff will NOT do.
Old May 12, 2017 | 03:57 PM
PJmak's Avatar
if they feel soft olio had leaked out making bush sound squeaky like a flat tire or thump thump noise
New ones were very solid and could not be moved by hand. The old ones were shot and can be rotated around by hand
Old May 12, 2017 | 04:09 PM
yeah I noticed your rubber was detoriated
Old May 12, 2017 | 04:13 PM
Pagz's Avatar
C43 w/clk55 Organs
Agreed the cap bolt pictured is 12.9
Old Jul 31, 2017 | 04:01 AM
W202AMG's Avatar
W202 C43 1999
What is the part number for these?
One of mine is pretty loose after a bang from the right rear when i threw the boot in at about 55kph and had that serious boot up the **** that 5.4ltr seems to want to deliver on demand...
The car still drives ok, minor wandering though, which is much worse under heavy throttle.
