CODE in Flashing Stop Lights project
Old 04-13-2017, 04:55 PM
member
pmercury's Avatar
CL
So, I swapped the old ESP module with the new one
seriously, it was plug'n play
2205451832 to upgraded 2205453532 model 804
unfortunatly, it didn't fix the problem
but, I don't know if my old module was bad (without giving DAS fault, yes, that exists)
or that the new one has a FAAAAAAR better ESP management
with ESP on, my car is unrecognizable, so sick compared to before
at least I had a little reward today
so I'm going back to investigations
stay tuned
and if anyone has a W215 with these dam adaptive stoplights working,
PLEASE PM ME !
thx
the one on the right is the new one (I know, it looks older, but watch the dates)
Old 04-13-2017, 05:42 PM
ItalianJoe1's Avatar
2003 CL 600
What changed about the ESP now?
Old 04-13-2017, 06:34 PM
member
pmercury's Avatar
CL
the new version seems to manage the slippery better
it's not holding in the power like before
Old 04-13-2017, 06:51 PM
member
pmercury's Avatar
CL
seriously, I bought mine for only 50£ thats like 70$
Old 04-14-2017, 12:05 PM
  #30
member
pmercury's Avatar
CL
giving it a last try with the very latest rear SAM module HW30/02 SW 10/03 next week
the seller agreed to exchange it for the version I initially ordered
stay tuned
Old 04-17-2017, 04:32 PM
  #31
member
pmercury's Avatar
CL
he says "It needs to be one of the last 2008/2008 rear SAM. ESP is not involved and has no such coding."
but that is not true probably, as Xentry says "from build 804"
so I mailed him back...
let's wait
Old 04-18-2017, 07:15 PM
  #32
member
pmercury's Avatar
CL
some info
Old 04-25-2017, 05:49 AM
  #33
member
pmercury's Avatar
CL
very latest HW and SW module is arriving by Thursday
one more test
stay tuned
Old 04-29-2017, 02:08 PM
  #34
member
pmercury's Avatar
CL
still waiting for the package ....
Old 05-03-2017, 12:37 PM
  #35
member
pmercury's Avatar
CL
installed the latest module today but it still doesn't work .....
in my eyes it is a coding problem
I couldn't find any other changes in terms of hardware from 803 to 804
as I have nothing to compare to ... (I don't have a 804 car here) nothing more I can do now..
anyone with a 804 car and DAS or other help is welcome
Old 05-03-2017, 03:06 PM
  #36
v8mercedes's Avatar
CL 600 '04, Porsche GT3 RS '08, CLS 500 '05, SL 500 '92
oh, these are sad news.....
tomorrow we will have a w220 s600 TT in the workshop with code 804. i will check the codes, maybe it has the K11.
what information do you need exactly?
pmercury (05-03-2017)
Old 05-03-2017, 07:30 PM
  #37
member
pmercury's Avatar
CL
what I would need is:
easyest thing would be to activate flashing stop lights
do that directly in developer mode,
REAR SAM> DEVELOPPER MODE> Diagnosis to plant specifications> control unit adaptations>
set Blinkedes Bremslicht V to 0 km/h
then activate flashing K11 option in
REAR SAM> Diagnosis to plant specifications> control unit adaptations> read coding> flashing stop lamp
if this works, the K11 option, then
Best thing would be to print to PDF all this:
CHASSIS> ESP> Control unit version
BODY> CGW> Control unit version
BODY> CGW> Control unit adaptations> read coding and change if necessary> all codes
BODY> CGW> development data> Control unit adaptations> variant coding> globale variantcodierung>
REAR SAM> control unit version
it's a lot for maybe, but that is minimum I need
thx a lot !
PM me when done
Old 05-05-2017, 12:23 PM
  #38
v8mercedes's Avatar
hi, the customer with the S600 missed his appointment......
on monday he will give up his car again for a few days. then i will check all your points and print the codings in CGW for you.
but sadly we have no developer DAS, just the basic version. hope i can find the informations to help you.
Old 05-07-2017, 07:49 AM
  #39
member
pmercury's Avatar
CL
thx great news !
Old 05-12-2017, 06:11 AM
  #40
member
pmercury's Avatar
CL
what day is you monday on ?
Old 05-13-2017, 04:41 PM
  #41
member
pmercury's Avatar
CL
Old 05-14-2017, 02:55 AM
  #42
v8mercedes's Avatar
please take patience!!!
the car is getting a complete new ABC system with all parts. i was not able to check the modules because everything is disassembled into its components.
you will get your informations soon!
Old 05-14-2017, 03:27 AM
  #43
member
pmercury's Avatar
CL
thx, good luck with the ABC ! I am a ABC fan as you know ! lol
Old 05-18-2017, 05:01 PM
  #44
v8mercedes's Avatar
You got a pm.....
Old 06-09-2017, 05:43 PM
  #45
member
pmercury's Avatar
CL
Back to this project
the data from v8mercedes didn't help unfortunatly, but thank you very much !
ordered a 2006 central gatway control Module a1695406945
in this upgraded version i'll be able to play around with options
never give up
Old 07-13-2017, 08:05 PM
  #46
member
pmercury's Avatar
CL
After looking closely again into this problem
If you activated the flashing stop lights in DAS Xentry
they should only work with EMERGENCY braking
so no wonder that we couldn't see it working stationary
I'll test this out tomorrow if I have time
but get a friend drive behind you (on good distance) then brake like hell and see if it works
BAS should trigger this
Old 08-17-2017, 02:46 AM
  #47
v8mercedes's Avatar
i have done that.
it works fine. you can see the flashing lights in the night in your rear mirror while doing a full brake.
after that i upgraded my data card in VeDoc with the code K11
Old 08-17-2017, 03:13 AM
  #48
member
pmercury's Avatar
CL
can you detail that in steps ?
I am saying this because updating datacard via Xentry is online only and you'll have to pay for it
also, by updating online with the MB server will delete all your custom programming and mostly always your tune
and a dealer with probably refuse
Old 08-17-2017, 04:07 AM
  #49
v8mercedes's Avatar
the upgrade in the data card is not necessary for the flash-function.
i just did it for the sake of completeness that my data card is up to date.
i complete the upgrade at my workplace because we have the clearance for that job. what you mean "by updating online with the MB server will delete all your custom programming" is a SCN coding and is not able at the C215s.
you just need to change the coding with DAS in the rear SAM from "deactivated" to "activated" and it works fine.
pmercury (08-17-2017)
Old 08-17-2017, 05:12 AM
  #50
member
pmercury's Avatar
CL
ok, then it's clear and no confusion for people reading this
- Just use Xentry and enable the option. Nothing else needed
thx!
Quick Reply: CODE in Flashing Stop Lights project
