C63 AMG (W204) 2008 - 2015
Aftermarket wheel Thread.
Old 05-23-2017, 03:49 PM
  #2601
computertom's Avatar
2017 911, 2012 C63
Just heard from the shop, the front K&W V3's and HRE's seem to be beyond rubbing. Need to take a trip over and see what's up. Was really hoping to not have to run spacers up there.
Old 05-23-2017, 06:11 PM
  #2602
Mort's Avatar
The KW's do seem to allow less room to the inside than the stock struts especially the spring perches tend to interfere with the tire sidewall. You may have to raise it up some and if that doesn't work add spacers to clear the strut. If your offsets are OK and you clear the struts you may have to go down a tire size, raise the suspension or run spacers to avoid rubbing.
computertom (05-23-2017)
Old 05-23-2017, 10:11 PM
  #2603
2017 911, 2012 C63
The folks from my (very, very awesome) shop dug out a brand new set of 5mm spacers and well, I got to drive off. But, we'll have to figure out something a bit more real to move forward as 5mm spacers are not hubcentric and definitely not appropriate for HPDE or other fun stuff that happens on the other side of 65mph. Will report back when we get to a good place (that hopefully isn't another set of HRE's with less offset as well, they're lovely, but they're not cheap).
-Tom
Old 05-24-2017, 04:24 AM
  #2604
Phil Chow's Avatar
W204 C63
-Tom
Tom, since you have front camber adjustment, dare I say you could size up to potentially a 10MM up front, and then it'd be hubcentric.
Other than that, doesn't seem like you can do much. I had plenty of clearance with my AirRex Struts on the P40SCs, didn't know hte KW Coilovers were that much thicker!
Old 05-24-2017, 02:29 PM
  #2605
2017 911, 2012 C63
Going to try a 10mm Hubcentric tomorrow and just get the Camber to a good place. Will snap a pic or two under there if anyone's interested.
Going to raise the rear a bit as I had some rubbing this am. Also seems that the rear springs have definitely settled a lot in the first day or so.
Still getting used to the new coilovers, but initial impression is quite good.
-Tom
Old 05-26-2017, 07:19 AM
  #2606
saulgoodman's Avatar
2013 C63 AMG Sedan P31
Looking good Tom! To continue the bluecrew.. here's mine. She still needs a drop though..
Old 05-26-2017, 06:05 PM
  #2607
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
-Tom
I got the same set as u & I'm 100% sure a 10mm spacers will make matters worst. Adding camber will kill the tires lol
Old 05-26-2017, 06:12 PM
  #2608
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
What is the world is the hideous thing the arrow is pointing to???!!!!
I don't think I have seen something similar in a loooooooong looong time...
Old 05-26-2017, 06:18 PM
  #2609
Roswell's Avatar
The savagery on this forum is real
But I agree, that was my first mod. Couldht stand the Orange markers.
Old 05-26-2017, 07:07 PM
  #2610
604 C63's Avatar
2012 E550 Cabrio
I have taken to calling this place "The Octagon".
Last 6 cars I have owned amber delete has been my very first mod.
Roswell (05-26-2017)
Old 05-26-2017, 10:35 PM
  #2611
Alex.currie44's Avatar
2009 SLK55 AMG
I want to get rid of mine but everything so far has listed up to 2011 which suggests PFL only.
Anybody got a led on on FL 2013?
Old 05-27-2017, 01:04 AM
  #2612
604 C63's Avatar
2012 E550 Cabrio
I've heard this, but before I had ever that I took the ones off my PFL and put them on my FL and they fit and worked fine. I can find you a link if you want Alex, but it was just off EBay Im pretty sure.
Old 06-21-2017, 09:03 AM
  #2613
Phil_T's Avatar
C63 AMG Saloon
Guys would I have any problems in the future with coilovers and this set up below?
19x8.5 et35 245/35 tyre
19x10 et55 275/30 tyre
Old 06-21-2017, 09:54 AM
  #2614
2009 SLK55 AMG
http://www.willtheyfit.com/
Old 06-21-2017, 10:41 AM
  #2615
Phil_T's Avatar
C63 AMG Saloon
Ive asked the question like most people in here for fitment questions, Plus I have no clue what so ever the specs of the standard optional 19's
Old 06-21-2017, 11:00 AM
  #2616
604 C63's Avatar
2012 E550 Cabrio
Ill give credit where credit is due, to my wheel guru
Specs are the same for both sizes though.
Old 06-21-2017, 11:20 AM
  #2617
2009 SLK55 AMG
It is all in the owner's manual. This is a 2013.
Old 06-21-2017, 11:21 AM
  #2618
2009 SLK55 AMG
Oops! Something went wrong. PM me with email and I will send if interested.
Old 06-21-2017, 05:51 PM
  #2619
Mort's Avatar
You should be OK. I ran 275/30/19 on the back on 19x10 ET+52 and rubbed slightly on the right rear. With ET+55 you should be fine as I was rubbing on the outside joint between the bumper and quarter panel.
The front will be tight but will depend a little on how low you go and if you can adjust your caster. I ran 245/35/19 on 19x8.5 ET+44 with a 13mm spacer and was OK on my 2012 but not my 2010.
On the front I am currently running 255/30/20 on 20x9 ET+33 and I am fine with no rubbing but I did raise the coilovers a little.
Old 06-21-2017, 06:50 PM
  #2620
saildoc's Avatar
2012 C63 black series, 2015 C63 507 coupe, 2012 Porsche Cayman R 4.2L 404hp
Originally Posted by need2speed
Anyone mount Enkei wheels on C63? The RSM9 on the Rack is under 20 lbs for 19 x 8.5
Yes, had them and loved them
Old 06-26-2017, 09:06 AM
  #2621
Former Vendor of MBWorld
VossenWheels's Avatar
Mercedes Benz E63 S Renntech Stage III
Old 07-27-2017, 08:59 AM
  #2622
Phil_T's Avatar
C63 AMG Saloon
Wheel guys another fitment setup.
1st Set
E89 20"
9 Et40
10 ET53
That should mean a flush front fitment on a 245/35/20 but what about the rear on a 275/30, flush fitment is normally et50 so I am guessing 3mm further in isnt going to look any different? (My tyre sizes may be wrong as not used to 20")
2nd Set
E88 19"
9 offset38
10 offset51
Is 2mm further out on the front going to be ok for fender clearance and 245/35/19? That rear et is pretty much perfect at 1mm closer in.
Old 07-27-2017, 09:07 AM
  #2623
604 C63's Avatar
2012 E550 Cabrio
Phil, I would take the 19s. The fitment works better for you, and I would really think twice before I would do a set of 20s. They look sharp as hell, but very guys have enjoyed the ride, and there just isnt a lot of rim protection there.
Old 07-27-2017, 09:17 AM
  #2624
Phil_T's Avatar
C63 AMG Saloon
I will most likely as I know I will compromise how well it will handle but thought I would still get both specs checked so I have options but need to see if I am ok with the specs for strut, fender and tyre.
The plan is to get the wheels for the car as it is now then when I do the metal fenders at a later date I can change the barrel and dish to suit. Plus the 20's makes the center look small on these but on the 19's they look ok because the center is the same size (20's below)
Old 07-27-2017, 03:20 PM
  #2625
SPONSOR
DCTMOTORSPORTS's Avatar
W211 Estate
Signature Wheel SV108 for W204 C63
We offer Signature Wheel for Mercedes community
Good quality forged wheels with very good price and delivery time
SV108 is Signature Wheel new model with directional design
if any C63 owner looking for a set of 19" forged wheel, PM us for a first adapter price
Quick Reply: Aftermarket wheel Thread.
