C63 AMG (W204) 2008 - 2015
Is this much engine ticking noise okay? Or do I have lifter/cam problems?
Old 07-11-2017, 10:57 PM
NotABaller's Avatar
2012 C63, 2014 E550
Video is here:
This is after driving and oil has been fully heated and circulated.
Been noticing this sound more recently. Don't know if it's because sound is getting louder or I'm just paying more attention to it. I drive the car every day. Just replaced motor oil with Mobil1 0w 40 and new oil filter.
Anyone have vids of how their engine sounds?
And if I indeed have lifter problems, how bad is it to just keep driving and ignore it?
Old 07-11-2017, 10:59 PM
MTV10's Avatar
E55 AMG & C63 AMG
Sounds fine to me. Stop stressing and just drive the damn thing./
Infiniti (07-13-2017)
Old 07-11-2017, 11:03 PM
NotABaller's Avatar
2012 C63, 2014 E550
Ive been driving the dam thing alot. Just want to make sure I can keep driving the thing for a long time!
Old 07-11-2017, 11:24 PM
BLKROKT's Avatar
Received 2,827 Likes on 1,670 Posts
That's just how they sound with 0W oil. If it bothers you, switch to a 5W.
Old 07-11-2017, 11:32 PM
NotABaller's Avatar
2012 C63, 2014 E550
I put in 0W because I read that its healthier for the engine. Is this sound normal for a fully warmed engine? Been driving for about an hour and this is what it sounds like. Pretty much all the time.
Its not the sound itself that bothers me, its the uneasiness I feel because I associate the ticking with something bad. So you guys are saying that this sound is not that bad and its quite normal?
Old 07-11-2017, 11:36 PM
bhamg's Avatar
C63 AMG
I'll take your question seriously. Your car is noisier than mine, even when I used M1 0W-40. There's an underlying prominent mechanical noise that I don't hear in mine, this being a noisy engine in general notwithstanding. That said, I've heard other M156's that I'd say have been noisier than mine and they certainly have seemed to be healthy, well cared for engines. My advice is to listen to some others side by side. There are quite a few knowledgable GTA'ers who post here, try to hook up with a few and do a comparison.
edit: The odds of anything being amiss re. perceived engine noise that hasn't been talked about here is minimal to (most-likely) non-existent. The remedies are known and not too expensive, relatively speaking. The suggestion to use 5W-40 is a good one. Do it. I use this oil in another car with excellent results. My local Walmart had it on the shelf this week @ $7 qt/btl...I thinks it's a great choice for this engine
https://bobistheoilguy.com/forums/ub...pics/4082881/1
NotABaller (07-12-2017)
Old 07-12-2017, 01:26 AM
xKryptonite's Avatar
C63
Also I think this is the sound of the purge valve. If you place your fingers on it, you'll sense the same pumping. Totally fine and normal. Lifters and cams will sound different. You'll feel it's more of a knock. If it's squealing and not the pumping which is the only thing I hear, check your belt and pulleys.
Old 07-12-2017, 07:30 AM
Vladds's Avatar
2010 C63 2019 GLA45
Sounds normal. Also mine sounds better and better after driving it for close to a year, with Castrol 0W40 European .
We should just have a thread with videos taken from the same angle, where everyone good and perceived-to-be-bad would post and someone that has concerns could listen to a known to be good sound and understand where they are.
Old 07-12-2017, 08:38 AM
NotABaller's Avatar
2012 C63, 2014 E550
Thanks for the replies everyone. If anyone wants to post a vid of their engine, feel free to do so in this thread! Definitely looking to meet up with a GTA'er and listen to your engine, as weird as this sounds LOL
Old 07-12-2017, 03:36 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Stop freaking out, that sound is normal.
There is a reason why the hoop has sound damping material.
Keep the hood closed and don't worry about it.
You don't need to open the hood and drop another bolt or anything else into the engine bay.
Have you noticed a rumbling sound when getting off the gas yet?
Old 07-12-2017, 07:38 PM
NotABaller's Avatar
2012 C63, 2014 E550
What oil temp do you guys run at?
My car goes up into 110C+ almost every time I drive. Saw it as high as 118, and I wasnt even pushing it. Just sitting in bumper to bumper traffic. The radiator fan is almost always on these days. Changed oil, oil filters, and just did charcoal delete and installed K&N filters today and oil temp hasnt changed. This is okay?
Old 07-12-2017, 07:53 PM
BLKROKT's Avatar
Old 07-12-2017, 08:11 PM
bhamg's Avatar
C63 AMG
NAB - Check your PMs.
Old 07-12-2017, 09:32 PM
bhamg's Avatar
C63 AMG
Here's a super-short vid shot today panning from very close to normal standing distance which demonstrates how near to the engine you need to be to hear ticking. From 3-4' away it's quite quiet.
File Type: wmv
Old 07-12-2017, 10:12 PM
Jasonoff's Avatar
Received 1,587 Likes on 935 Posts
2010 C63 AMG
Mine is way more quiet than that with M1 euro 0W40. This is the first start after doing the HB as well.
Old 07-13-2017, 04:20 PM
Infiniti's Avatar
a unicorn tuned p30 e63
Did you drain all the oil out of the oil cooler? I'm nuts about changing the oil on my car and try to get out all the bad dirty oil, I waste about 3qts of new oil until it bleeds clean. yeah I know a bit much but I its what I've always done.
https://www.youtube.com/watch?v=WbbTYs8kwRo
mighty clean in there sir, maybe I'm wrong but didn't you say somewhere ur car has a couple miles on it?
Old 07-13-2017, 04:23 PM
HBC350's Avatar
'18 C63A Cabriolet
Video is here: https://youtu.be/Jn6-wbV4t3o
Sounds more like injector click to me.
Old 07-13-2017, 05:50 PM
realjones88's Avatar
2012 C63 P31 sedan
Run Shell Rotella T6 or Motul 8100 5W40 and I bet the car doesn't make that sound anymore.
Old 07-14-2017, 09:31 AM
Jasonoff's Avatar
2010 C63 AMG
Different oil can quiet the injectors?
Quick Reply: Is this much engine ticking noise okay? Or do I have lifter/cam problems?
