To plasti-dip or not....
Thanks in advance.
Glossy or matte? Any pics? Does it hold up to washing?
Did you remove the diffuser or spray with it still attached to the car?
For sure doing the front, problem is I live in a rural area, bugs are pretty bad out here, that's why I asked if the plasti-dip will take to pressure washing.
I would suggest practicing on something before actually applying to your car. Never hurts to get a feel for how it covers.
1) I've seen a number of videos from DipYourCar on YouTube and it seems pretty straight forward. Given that I don't want to dip the entire car, can anyone recommend if I should leave the part on and tape-off the surrounding area when dipping it, or if I should remove the part to dip it.
2) I have a colleague that dipped the wheels on his car matte black. Given that it's years later now, they look pretty bad. I never got a chance to see them when they were new - does dipping actually look like a tacky matte wrap job right out of the gate?
3) Is there a preferred brand people use? The most convenient for me to pick up is: https://www.homedepot.ca/en/home/p.p...000747809.html. Not sure how I feel about applying a $20 spray to OEM parts that are probably pretty expensive to replace if the spraying doesn't go as planned or doesn't peel nicely even after multiple coats.
Things to remember...
- It's completely removable - even over spray particles come off reasonably easy, even without a machine.
- It's not the same as conventional paint. It's not going to be mirror smooth as glass like your car, but it can have a good sheen appearance. There are gloss and matte products that can push one way or the other.
- It's easy to touch up. Yes, a front splitter or wheels are going to receive a ton of debris impact. With that said, with a small amount of effort for masking, a whole splitter could be touched up in less than 30min.
Plenty of examples online, but I just saw this guy at my local Cars & Coffee...looks flawless. 100% PlastiDip
I am thinking of wrapping my chrome strip on the trunk, and the side skirt trim. Just wish I knew how to get that off to do it well.
The front lip is holding out very well - I have had it on for 8 months and through a winter. No sign of any touch-up work needed.
... be generous, and be patient.
Mask well so you can't overspray. Overspray doesn't hurt but it is annoying.
Put plenty on. Maybe two or three thin coats rather than one thick coat.
Be cautious when taking your tape off. Maybe cautious use of an art knife.
Hope that you don't mind. Just my (limited) experience.
Before pic;
Needs a wash, lots of bugs where I live.
