Car has 96,000 miles and twice a year was thoroughly check by service department for any imperfections
Over last 4 years anything that popped up was fixed under warranty.
- Entire front ABC suspension
- right front headlight with control computer.
- engine mounts
- climate control blower
- rear window shade mechanizm
- driver side key less entry sensor / handle
head bolts never came up - so "No" head bolts not done.
just want quote fellow forum member:
"I've mentioned that to two dealerships when getting normal maintenance done. Both said there is no reason to go into the engine without signs of an issue. I know everyone on here will say do it to prevent but the head bolt issue is way over hyped as an issue with these cars. I was also told signs would have shown up around 40k miles"
My car even after 97000 miles is as strong as tank !!!!
