Do all C63 pull to the right after H&R sport springs are installed?
I have been reading and have talked to a few shops that install H&R sport springs on the C63, and the common complaint from everyone is that the car pulls to the right after install.
Has anyone installed them and not had this issue?
Mine tracks straight and true. No crash bolts were used. I went to an Indy shop.
Nah, I read back in the days about that same issue so it's not only related to the coupe but also the pre-facelift sedan.
I was also worried at first, but my wheels needed a drop to look good.. So I took the chance & it worked out perfectly. I don't think I got lucky, just had a good mechanic do the install.
I will put the HRE's on a see how they look at stock height.
Mine is a 14 507 Coupe with HR springs. Alignment was done after the install (of course) and it runs like on rails.
I can not imagine, why it should or even could be any other way, if it is done right!
My car has H&R springs and pulls right. Alignment had been checked several times and it's all good. Tires wear as good as I coild expect as well. I've learned to deal with it. I found on 4 lane highways its pulls left when in the left lane, so I chalk it up to the crown on the roads.
Well, that sucks.
I am supposed to be installing them this upcoming weekend. I really don't want to mess up the suspension as the car handles very good now and drives straight as an arrow.
What to do.
What to do.
2012 C63 w/APX
From what I know about MB, they all pull ever so slightly to the right. I've been told this is a built in safety feature so the car will naturally veer away from traffic (in right hand driving countries) if the driver was to doze off.
If your car is pulling hard to the right, then as others have mentioned, it probably needs an alignment check.
I think you mean left hand drive countries. Right hand drive is England and Australia for example and NA is left hand drive. Remember left and right in a car is taken from your position seated behind the steering wheel.
most people also throw cheap tires on aftmkt wheels when they lower the car too which compounds the problem on top of needing an alignment.
After installing H&R Springs ALL C63s will pull slightly right - even after alignment! This is what Ive been told from a shop that has done A LOT of H&R spring installs here in Toronto.
For those that said they installed and the car doesnt pull they are wrong because I did it in my P31 Sedan and had an alignment done twice! The car still pulled SLIGHTLY right!
I would love for you to post your alignment! Its virtually impossible to get it perfect using laser alignments. No matter what the car still pulls slightly right whether you are aware or not.
I havent but the guys in the shop have and I trust them. Also the 15+ C63 owners I know in Toronto who have had their cars all lowered on H&Rs admit their cars track slightly right.
https://mbworld.org/forums/c63-amg-w...-h-r-drop.html
And the majority of roads in North American have a slight slope of crown towards the shoulder. Some also have them towards the center or left. Our cars are pretty sensitive to crown. With a right sloping road, yes the car fades right. Same with a left crown. And on roads that are pretty much flat, the car does not pull or fade to either side. Prior to installing the springs, my car did fade to the right a little as you have mentioned. On left crowns when stock, it would hold straight. Now on the same roads it just follows the crown.
There have been many threads here about this and basically what those threads say is that you need to buy adjustable alignment bolts and the stock ones are not adjustable... after that it track true... hope this helps
https://mbworld.org/forums/c63-amg-w...lls-right.html
Alignment after H&R install
Hi All,
At the risk of beating a dead horse, I just wanted to see if I understand what is going on here. I lowered the car and added 12MM spacers. I then aligned the car. I would'nt say it "pulled" right but she did "drift" to the right if I took my hands off the wheel on an interstate. I never noticed this tendency before i did the lowering so was a little concerned.
I work at a race shop and have access to a very fine crew and all the best equipment. The tendency to move to the right is not noticeable when i'm "busy" just when cruising and is only mildly annoying. Am I being too picky?
Will adjustable camber bolts cure the issue and if so how are they used on the W204.
Cheers.
Cheers.
Detailer1 (03-30-2016)
