brakes upgrade with amg
hello to everybody.
i want to improve my brake system...
front i have oem 375 mm rotors
rear oem 330 mm rotors.
2 questions.....
wich amg caliper will be plug&play? front and rear... ( i love gold colour ones )
will i need to change my rotors??
thanks to all
2 questions.....
thanks to all
The following 2 users liked this post by WaveyKat:
a100steaksauce (01-04-2017),
Ariane (11-26-2016)
What CAN be done to improve brake feel and performance? I've upgraded rotors and pads and there was a slight improvement. But everytime I drive the SUV (it's my wife's, I drive a sedan) I have to get acclimated to the poor stopping distance/feel/performance.
remember, you are driving a 5000 pound truck...
![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
better pedal feel with braided lines? absolutely. but i dont believe they exist for the x164. the oem should be measured and a generic braided hoses can be then picked up.
I doubt anyone driving a gl anything would see an improvement in pedal feel from going with ss lines. You would have to be doing narly corners etc to get the fluids temps up high to really notice. The same could be experienced by simply replacing the old rubber that in some of these cars are almost ten years old plus how often do people really replace there brake fluid etc
Former Vendor of MBWorld
Upgrade the front to AMG size (390x36) complete BBK.
http://www.racingbrake.com/ProductDe...uctCode=2245-K
The rear can be upgraded to light weight two piece rotors.
http://www.racingbrake.com/Two-piece...166-p/2538.htm
Racingbrake has all the brake upgrade you are looking for.
http://www.racingbrake.com/SearchResults.asp?Cat=7288
ajax50 (02-07-2022)
hello
i have upgrade big brake kit to an ml w164
6pot original amg caliper with 390 rotors original amg
Great stopping power with factory parts
if you want a same amg brake kit just pm me
ajax50 (02-07-2022)
We've got a similar PKG for the G Wagen, precisely because the factory calipers look terrible. Check it out: http://speedriven.wpengine.com/2016/...e-upgrade-pkg/ I don't think it would work on the GL, but if you get 2-3 other people interested we'd make an upgrade PKG.
wich amg model goes with 380-375 mm front discs???? with brembo caliper??
and rear 330 mm ??
wich one???
the question is... i want to put oem amg calipers...... wich ones i need to buy..... plug and play..
thanks to all
and rear 330 mm ??
wich one???
thanks to all
ajax50 (02-07-2022)
Something Slow
also: I was looking at the 2006-2011 W164 ML63 Brakes It Doesn't Look Like its the Same caliper in your picture. see the picture I attached for example..
so I understand you used the Rotor 390mm From W163 ML63
which model 6pot AMG Caliper did you use?
and also what setup did you use for the Rear Rotor & Caliper?
thank you
Can you send me some pictures of the kit you have??
thank you
thank you
photos you can see in latest quote
i use the latest amg calipers 2016
rear i install the original ml63 amg set up,1 piston caliper with 365 drilled rotor
the question with brembo front brembo calipers is the adapter...
wich one and where to buy?
like these
https://mbworld.org/forums/e-class-w...s-upgrade.html
http://www.w124performance.com/image...iston_info.pdf
like these
The following 2 users liked this post by Ariane:
ajax50 (02-07-2022),
Audi Junkie (04-01-2021)
