Gas attendant pumped regular last night
Yeah the car will adjust to low octane due to knock sensors. Just won't have full power until you refill with premium
You can always throw in a bottle of octane boost if you want full power with this tank of gas
All US-spec vehicles since 2001 must retain an "alternate fuel map" for use with gasoline of lower spec. Yes, that map will provide lower horsepower - on the order of 10% or so - but there is no harm involved whatever.
In fact, I run NOTHING but Regular gas in my CL500, many years now. Used to be a 20-cent difference for Premium, but these days it is 50-cents and more. I don't use or need that extra 10% horsepower on a daily basis, so why not?
If you say "engine longevity" I'll correct you: the engine only "needs" that extra octane a tiny percentage of the time, for example under full acceleration on a hot day. ALL the rest of the time, that 93-octane stuff is going to WASTE, not needed in the slightest for normal driving. Even under full acceleration, the Alternate Fuel Map and the knock sensors will prevent pre-ignition and potential for damage. And I so rarely drive anymore under full acceleration!
If you are under full acceleration all the time, by all means spend the money for 93-octane. If you drive normally, however, there is NO DIFFERENCE to the engine using regular-grade gas.
05 E55, 98 CLK320
