E63 M156 Updated Dipstick
SPONSOR
2007 Mercedes E63 AMG
hey guys,
any idea why Mercedes updated their dipstick? my original one's grab loop was broken so i ordered a replacement. the replacement was a red handle vs a black and made from flat steel vs metal cable.
only thing i could think of is the cable could get kinked and not return to proper shape which could cause false readings whereas the flat metal if bent could easily be bent back to give proper readings.
I also had the grab hook on my cable type of dipstick break. Ordered one from the dealer which when I got it was a metal type dipstick. I asked the parts guy and he told me this is the latest rev. of that part. I told him that this was for a 2007 and was told that this dipstick is for the M156 engine. Well it was a good thing I did not throw the old one away, when comparing the two, the metal dipstick is overall longer and the plastic marking ***** are in different locations. So now when I use the dipstick to check the oil level, I have the lay it out against the old one to see where the level actually is
SPONSOR
when i did the comparison, the plastic markings were pretty close. the newer metal dip stick did look like the high marking was a few mm lower than the factory one, but nothing to worry about.
did you do a comparison from the lower o-ring?
My Tech informed me, that MB had a service bulletin out for this part. Once he examined my E63, he found that oil was be forced up thru the dipstick at high RPM. The new dipstick and cap doesn't allow this to happen.
Hi All,
I checked my oil today and found out that the red bottom part of my dipstick, the part that has min-max marks on it, has cracks. I want to change the dipstick before any plastic falls comes out and falls into the engine. Does anybody know the part number for 2007 E63 Amg? I can't find it on parts.com. Thanks in advance.
Hi All,
Thanks, I put that number in search and according to ECS tuning it fits my car: https://www.ecstuning.com/b-genuine-...ck/1560101772/
But according to MBOemparts it won't: https://www.mboemparts.com/oem-parts...PWxheWVyXzg%3D
I will use that number in parts.com and ask them to verify it will fit before shipping. Thanks
I just did a search for a 211.077 matching the car description you provided (2007 E63) into EPC and that is the last updated part it provides.
HI all, I hate the updated dipstick. It is so much harder to read the level. The factory one was much easier. The metal piece always gets stained with oil making it harder to see where the level is.
I drained all the oil including the oil cooler, then put 8.5 liters of oIL and it is above the max according to the updated dipstick. How in the world? Doesn't m156 hold 9.5 liters? I wish I kept the factory one
If you put in 9.5 quarts, then you are good regardless to what the dipstick is saying. I always put in 9.5 quarts, and have never had any issues in 11 plus years of ownership.
tlambert (05-29-2018)
Just came back from the dealer. The confirmed that the updated dipstick I bought had correct part number. They cannot understand why putting 8.5 quarts brought the dipstick to above max level. They also confirmed that the engine takes 8.5 liters or 9.5 US quarts. They shrugged their shoulders and recommended bringing the car in for the next oil change and have them do it, so that they can measure how much oil goes in.
I did another oil change today and added 7.5 quarts. Checked level and it was just under the max (second mark) on the dipstick. How in the world? Poured one full 5 quarts bottle and attaching the picture of the second one. Added a little more later just to be safe - about 8.5 total. Scared that adding 9.2 may cause damage to gaskets and stuff.
SPONSOR
sorry for the bad photo. here is my dipstick after last fill up. we drained the oil cooler and oil pan and then poured 8.6 quarts into the engine and then started her up for 5-10 minutes. afterwards we checked the dipstick after normal operating temperature. oil was GROSSLY over the max fill line. checked the dipstick 3 more times for safe measure and confirmed...yes this new dipstick reads entirely wrong. added 0.8 more quart with a big middle finger. last oil change my mechanic used the dipstick as a measurement and about 1500-2000 miles prior to my next oil change, my low oil light came on. i did hoon the car quite a bit, but i've never had the low oil light come on prior to the new dipstick even with hooning. also, i have had all oil leaks repaired and my engine does not burn oil. it does burn oil through the PCV if I redline and snap the throttle closed and coast multiple times...from what I gather, the PCV sucks all that oil vapor out and over time can lessen the overall amount of oil in the engine. this is expected generally speaking.
I think that they updated the dipstick, due to the possibility of the red plastic pieces could break off. Which wouldn't be good to have plastic bits floating around inside your engine, as a oil passage could become block.
what is the length of the original OEM engine oil dipstick? My CLK63 came with a broken one also and I want to replace it
E63007 (03-10-2024)
hachiroku (10-29-2021)
E63 Motorsports, you know the guys that make the alternative upgraded CamAdjusters, makes a replacement Oil Dipstick of a cable design attached to their own Custom Fabbed E63 Logo Handles. Only thing is, because they are made from Aluminum? they get really hot!😳 Also, unless you use a paper towel to absorb what is left damp from oil at the tip, it’s awfully hard to see oil on the cable much less both crimped-on markers? But at least they got the length right!
OG E63 m156 dipstick
My factory dipstick is discontinued and has cracks from old age. Some say the replacement is discontinued as well. Not sold on the 63motorsports unit. Any other options?dipstick is 22 and 1/4 from the bottom of the top of the dipstick.
