sunroof shade removal
Old 11-19-2017, 03:02 AM
clk350Driver's Avatar
2007 clk350 w209
Is it possible to remove the sunroof\shade. The sliding shade that is sandwiched below the sunroof and the headliner. Can it be pulled out without removing the headliner? This is for a 2007+ w209 clk 350. thanks
Old 11-19-2017, 09:50 AM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Open the shade fully, then open the glass halfway. There is a plastic trim piece on the bottom front for the glass. Remove it - it's just clipped in place, but beware that its plastic tabs may be brittle so some my break. Once that is removed, you can fully open the glass, and then slide the shade closed with the glass still open. From above, you'll see four slides, two on each side, that sit the tracks. These are spring-loaded so you can press them inward and release them from the track, then the shade comes out through the roof opening.
Wag230 (04-11-2019)
Old 11-19-2017, 04:21 PM
2007 clk350 w209
Hallelujah!
rodney ur insane.
Ill give this a try. Lmk if theres a video out there that demonstrates this, otherwise ill make an attempt myself.
My shade slides around freely, the detailer broke went and cleaning too aggressively, i might go to the junkyard to practice and to pick out a replacement shade.
thanks again
Old 12-02-2017, 07:46 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe kid: 2017 GLC SUV
They have "practice Mercedes" at junkyards near you? Where's that?
Old 12-02-2017, 08:48 AM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yeah, I wish we had good junk yards around here. The few we do have are pretty much full of old clunkers.
Old 04-24-2022, 09:37 AM
karayjay's Avatar
2006 CLK 350/. 2009 CLK 350/2005 Both White
Tilt the rear glass up. Then remover front black plastic cover at the front of the sunroof. The carefully remove left and right rubber waffles I call them pull out gentle . If you break then there are cheep 20.00.
The on each side of the sunroof # 25 torx screws . Push the sunroof up and out. Slide the sunroof slider forward. Look for 4 plastic clips at each corner and push them inward while lifting up and then slide the slider more forward to get the rears ones and you are done . When you install it back push the clips inward and it will drop in the track and stay in , you will understand when you so it .Most important !! slide it back THEN install the sunroof and test .
Old 08-26-2023, 05:42 PM
larry_diddle's Avatar
2008 e320 w211 bluetec
How do yo remove the front plastic piece?
How do I remove the front plastic trim? Are there tabes in the middle or is it only attached on the side. I really don’t wanna break this piece so can someone please tell me how they did it.
Quick Reply: sunroof shade removal
