Spacer help for wagon
Got the wagon set up today with 12mm rear and 15mm front spacers. Car is also lowered using the ebay module. Front tires look good, but rears are flush with fender, even appear to be sticking out a bit. Not sure I care for the look. According to Supreme Power running 10mm in back is not doable. Thinking about running 12mm in front and stock in back. Appreciate any feedback on pros/cons and any other suggestions.
Thanks,
Thanks,
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
I run 15mm fronts and 12mm rears with no issues and sticking out... here is a clearer pic of the rears. I have the Supreme ones so make 100% sure you have 12mm in the rear and not 15mm? Further, once you drop the car the wheels will camber in slightly and you will not see that the wheel sticking out. (can you post pics please)
I will post pics later. Rear wheels look about the same as yours jdhertz. Maybe I just need to get used to it. I raised the car slightly using the custom settings in the ebay module and looks better.
Originally Posted by cita
Very nice but the car on the lawn really bothers me a lot. LOL...
Administrator
Now if you do use the uploader on a large pic and use the preview button, it will appear that the pic is way too big but once you hit "submit reply" it will be reduced in size.
Administrator
Thats fine, they really are not sticking out its basically flush and when they camber during compression it goes in. You can check to see if there is any rubbing but I doubt it.
Thats exactly how mine looked before lowering.
2021 AMG GLE 63s Coupe AMG GLC 63s Coupe
I installed 285/30/20 on stock front wheels with a 12mm. spacer and 305/30/20 on my stock rears and went with a 5mm spacer and they fit perfectly with the car lowered..
Blackdog1. The wagon looks great with those spacers. I just want to confirm that you are running 15mm front and 12mm rear. Any issues now that you have been running them for a while?
