Steering column adjustment stopped working
Old 06-21-2018, 06:38 PM
Veteran: Air Force
Darel's Avatar
'14 W212 Sport, '52 MG TD, '21 Jeep Gladiator Rubicon
Disclaimer: I am a deployed reservist and won't be back around the car until sometime in Sept. My wife tells me the steering wheel adjustment has stopped working. Is there a fuse I can direct her to check, and if so, where is it - engine bay or trunk? Don't want her to go the whole summer with her own steering wheel stuck in my position. Obviously if it's more than a fuse it'll just have to wait for me to get back.
Thanks,
Darel
Old 06-21-2018, 07:56 PM
KEY08's Avatar
Received 1,625 Likes on 1,192 Posts
2014 E550-sold 😩
There have been many posts over the years regarding the loss of this function across all MB models. I don't believe it is a fuse issue. Here is one thread:
https://mbworld.org/forums/e-class-w...ming-down.html
Old 06-21-2018, 10:52 PM
cetialpha5's Avatar
Received 1,506 Likes on 1,177 Posts
You can try those methods, but in the W211, it was well known that the gear that moves it up and down can break, especially if you put weight on the wheel while it's moving. I've turned my easy entry/exit feature off to avoid this possibility.
Old 06-22-2018, 07:39 AM
Veteran: Air Force
Darel's Avatar
Thanks guys. I told her to try disabling / reenabling the easy entry to see if it goes away. Otherwise I'll have to deal with it another time.
Old 06-22-2018, 12:05 PM
El Cid's Avatar
I have a 2010 and the automatic easy entry/exit feature stopped working a few years back. This is where the S/W automatically goes up when you get in or out and then returns to preset position when you start car. Major problem to get it fixed. Dealer had car three days as it required replacing the unit itself and then getting it to communicate with car's computer and insuring car computer still communicated with dealer's and MBUSA's. Fortunately it was under warranty and they provided a loaner. Still working.
Curious. If you are not there, how many people are driving the car? If only one, is the setting being adjusted that much?
Old 06-22-2018, 03:22 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
Had this happen on my car. I could get it to work by wigging the switch up and down a # of times (somtimes 30 or 40 times) it'll work for a few days then stop working again until I did the switch wiggle again.
Took it in to dealer thinking it was a bad switch, they took it apart and said the entire assembly/motor was bad (switch was fine) They replaced it under the factory extended warranty. Took them a full day to do it. Asked how much it would've been without warranty they said a bit over $1k.
Old 06-22-2018, 03:47 PM
El Cid's Avatar
The Best or Nothing
The Best or Nothing
Quick Reply: Steering column adjustment stopped working
