Center vent removal
Old 07-19-2018, 12:10 PM
derekwh's Avatar
2012 E350 Bluetec, 2014 GLK250, 2007 CLK350 convertible
Center vent removal
Does anyone know of a video / link that shows how to replace the center vent? I found some old threads which mention it but are not very descriptive.
Old 07-19-2018, 08:07 PM
cindyclk's Avatar
just did yesterday but no video
gently pry rectangle climate controls units out...there are 2 large wire harnesses attached to climate control..there are sliding retainer clips holding them in place,,,remove and then the harness can pull off.
you will expose a plastic box that the upper controls slid into....remove 2 small screws to remove box.
There are 2 screws exposed on left and right...remove...this gives you wiggle room to pull the round plastic trim away from dash.
At this point, you can just tug on the entire vent and it will pull out.
Saying all this...When I got it out, there still was no air coming into my center console...no matter what I did with the actual vent. I still have to find where the flap that controls the air to the center vent space resides.....UPDATE...found a broken connector at the vacuum reservoir inside the right side front fender.....that should help after fix...I'll keep you posted
Old 07-20-2018, 10:29 AM
derekwh's Avatar
Thanks, I will give it a try. I don't have a flow problem, somewhere along the line the slider got broken. I am looking to replace the vent.
Old 07-20-2018, 12:40 PM
cindyclk's Avatar
post #5 gives WIS of removal
https://www.benzworld.org/forums/c20...rror-tilt.html
Old 07-20-2018, 04:31 PM
derekwh's Avatar
Thanks for the link, a question though, do I have to take apart the whole console or can I just remove the radio, HVAC and wood to get the vent out?
Old 07-20-2018, 06:40 PM
cindyclk's Avatar
I only loosened the top enough to make room...above
Old 07-22-2018, 07:47 PM
derekwh's Avatar
Maybe I am missing something, I don't see any screws. Do I need to get the wood off first? And of course I need to ask, how do I get it off without breaking it? Here is a picture of my dash.
Old 07-22-2018, 09:29 PM
cindyclk's Avatar
It just pulls off...gently!
Old 07-23-2018, 10:35 AM
derekwh's Avatar
Is it held on by pins or?
Old 07-23-2018, 10:47 AM
cindyclk's Avatar
It is held by spring like tabs...basically just friction held...nothing to unscrew...use a thin butter knife or something similar...once you can lift a corner, you can just work your way around.Seeing your picture, you should have no trouble getting it off because you have exposed all that area where climate control was...gently pull from there.
Old 07-28-2018, 06:37 PM
derekwh's Avatar
Swapped the vents, nothing broke and everything still works. . I can see where this will be a lot easier the second time.
Old 07-28-2018, 08:21 PM
cindyclk's Avatar
glad that it all worked out.
Quick Reply: Center vent removal
