Big Brake Kit Upgrade (cheaper then stock)
Brembo 390mm 2pc rotors.
My car need front brakes bad. Did this big brake kit 2pc rotor 390 mm from SoloMotorsports and cost me less then dammm stock replacement.
Received 1,886 Likes
How much for all parts?
they are brembo 2pc rotors 390mm I guess SL65 uses the same size. It comes with custom bracket for the calipers and new bolts and I got the TRW pads.
That's crazy!! for $ 1400 you can get upgraded brakes 🤣🤣 looks so much better inside the wheels too.
Terence E ENoh (12-19-2018)
Just made an order today cant wait...they are awesome ppl...much more to come from them for the m157 platform 😁😁😁🤫😎
- front rotors
- rear rotors
- front pads
- rear pads
- sensors x 4
all for $1400 shipped tax included??
Can we purchase the brackets alone? Or can they supply light weight giro disc 390 mm with brackets as a kit. Seems size is what’s upgrded which is great. I’m very interested on getting lager diameter rotors along with the saving of unsprung weight giro disc can add
check this thread out, https://mbworld.org/forums/w212-amg/...placement.html
I have a 2015 E63 AMG S, and replaced the fronts with the 2 piece rotors, (I believe it was around 750-800 for 2 of them, brembos)
I did the rears and fronts with sensors and all the parts cost me $1100....labor was cheap for me cause I have a mechanic friend (charged 80/axle).
Not trying to thread hijack here, but I just replaced my front rotors and pads this week as well and wanted to offer up another option.
After a lot of research on this forum and some if / then compatibility analysis, I bought 1-piece Zimmerman rotors (Part number 0004212012) from FCP Euro that were advertised for the C63.
These bolted right up to my base E63 wagon with zero issue. I understand that 1-piece and 1.5/2-piece are not equivalent performance wise, but I do not track, so I was not too worried about any loss of heat dissipation of the 1-piece vs 1.5-piece during daily driving.
The 1-piece rotors cost about $250 for the pair, and have the added benefit of the FCP Euro lifetime warranty. I paired mine with EBC reds and they're performing great a week in.
Here is a comparison of the Zimmerman vs my worn OEM rotors.
Girodisc only make 360mm no 390 mm I put my brakes on the scale the 390 mm 2 PC are the same weight as the oem 360mm 1pc. so no weight adding just going bigger and down the road you can buy only the rings.
Seems giro disc sells 390mm for the sls amg. Does anyone know if the offset is the same. That would be a great upgrade seeing as the giro disc are lighter then factory 2 piece. Rb also sells a big brake kit but they don’t list bracket to be sold separate
