C63/C63S AMG
First 9 second 1/4 Mile Pass, 9.97 at 140 mph Edition 1 Coupe
Old 03-21-2019, 10:39 AM
DSawyer63's Avatar
2012 C63 P30 Sedan
I ran my car at Beech Bend Raceway Park in Bowling Green Kentucky last weekend. The track was not prepped for street cars because they were doing bracket racing with a big payout and just needed consistency so traction was an issue, but I will try again on a better prepped surface in a couple weeks and hopefully get deeper into the 9s.
Quick mod list:
YP4 Turbos
3" downpipes
AWE Track exhaust
CF Air intakes
Comp Spec Cooling System
AEM Meth injection
Wavetrac LSD
2.65 Final Drive Ratio
Stock transmission tuned for more line pressure
stock engine internals
305/35/18 MT ET Street Drag Radials on CCW wheels
Full Interior
Fuel was 93 octane blended with 110 Renegade
The following 3 users liked this post by DSawyer63:
blaferty (03-22-2019), deftronix (01-18-2020), scrufy (04-16-2019)
Old 03-21-2019, 10:57 AM
purplewidow's Avatar
2019 c63s coupe, 2008 s63 sedan, 2007 335i coupe
Epic congratulations!!! My buddy who has met you showed me last night at his shop. Amazing!!!
Old 03-21-2019, 02:44 PM
Schulminator's Avatar
2015 C63s Sedan
Great run Doug!! What is your rear wheel size/offset? What did you find the best way to launch?
Old 03-21-2019, 03:17 PM
tekfoc's Avatar
18 E63S
Congrats.
What was the cost of the new LSD
Old 03-21-2019, 04:11 PM
DSawyer63's Avatar
2012 C63 P30 Sedan
Thanks brother!
Thank you! 18x11 +51 CCW C10 Corsair
Originally Posted by tekfoc
Congrats.
I believe it was around $1400 with bearings, seals and shipping
Old 03-21-2019, 05:22 PM
Vader-C63sE1's Avatar
2017 C63s Edition 1 JB4
Wow, that's impressive, congrats!!
Old 03-21-2019, 05:38 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Congrats...................
Old 03-21-2019, 06:01 PM
DaRuzzian's Avatar
2016 c63s
Amazing run! I just tuned mine, can hardly wait for a track day
Old 03-21-2019, 06:51 PM
KJ
KJ's Avatar
2020 GLE 53 AMG
Awesome achievement, congratulations!
Now it's time to race Brooks in his McLaren 720S!
Old 03-21-2019, 09:12 PM
FDNewbie's Avatar
'17 AMG C63S Edition 1 Coupe, '18 AMG C63S Convertible, '19 AMG GLS63
Nice run!
Could you elaborate more about this? Still haven't seen much info about this on the forum.
Old 03-22-2019, 04:35 PM
thebug44's Avatar
2012 P31 C63
Originally Posted by FDNewbie
Nice run!
This...
Old 03-22-2019, 10:36 PM
CarHol's Avatar
MB
how much nitrous running in car?
Old 03-24-2019, 04:45 PM
DSawyer63's Avatar
2012 C63 P30 Sedan
Nice run!
Originally Posted by thebug44
This...
Through tuning we were able to achieve more transmission line pressure at WOT to hold more pressure on the clutch packs. The result is zero slipping and a big increase in torque capacity. There is no sacrifice in drivability because at lower throttle and load values the transmission is still running stock pressure. Just quicker Full throttle shifts and increased torque capacity.
Silly question, but I will answer it anyway. No nitrous is necessary to make 1000 bhp out of the m177 when using twin 58/76 turbos and no nitrous is being used. The car that went down the track is the same car that I drive to the store or to work, same tune, same weight, same power adder.
Old 03-25-2019, 11:59 AM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Awesome time! That trap speed is just as impressive too. Congrats!
Old 03-25-2019, 05:52 PM
FDNewbie's Avatar
Awesome. I heard a while back something similar from Andrew (power technik) about increasing the trans line pressure through tuning. Who did the TCU tune for you? And my understanding is it has to be loaded on-site as the TCU is located on the trans itself? Would love to see if the shop who did this for you sells the tune file that you could then load onto your vehicle locally...
Old 03-25-2019, 06:29 PM
thebug44's Avatar
2012 P31 C63
Hmmm, I wonder if this is the answer to transmission limitations for this platform along with the w212... what he said curious to know more details about the tuning
Old 03-25-2019, 06:50 PM
mr747's Avatar
c63
For m177 and m178 platform TCU is tunable via OBD not TCU
And there are only a handful of people on this earth that can do it
Old 03-25-2019, 08:38 PM
BMS
BMS's Avatar
2018 C63 Sedan
Congrats!
Old 03-27-2019, 10:38 AM
DSawyer63's Avatar
2012 C63 P30 Sedan
The TCU is in fact tunable via OBDII
Old 03-27-2019, 10:55 PM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
Its definitely a fast pass but I can't help wonder why a 2.65 final was chosen ? Usually most would run in the 3. something rather than go down in the mid 2's . With my race car ( a 5.0 mustang ) I ran 4.11's with tall tires , making 1260 hp and ran mid 8's at 164 mph . Was the car more set up for 1/2 mile ?
Old 03-28-2019, 03:18 AM
FDNewbie's Avatar
So...who are these ppl so I can inquire about getting a TCU tune via OBD?
Old 03-28-2019, 09:54 PM
AV1
AV1's Avatar
C204 C250-CDI
The above is what most people do.
I'm thinking the taller diff ratio was selected to reduce wheel spin and improve traction because of the torque levels, also would give higher terminal speeds
Old 03-29-2019, 12:13 AM
mr747's Avatar
c63
Taller diff ratio was so he passes the line in 4th gear instead of 5th gear
Old 03-29-2019, 02:37 AM
AV1
AV1's Avatar
C204 C250-CDI
Makes sense, solved
Old 04-14-2019, 09:32 PM
Judson145's Avatar
C63S Coupe
How do you like the YB4 turbos? I see many customers with great results. Do you have more photos of them on the car?
Do you think there is more left in improving your times? Have you thought about reducing weight? I know here in Gulf we can have option of light weight seats and so on.
Great job once again. First and only 9 second c63.
Quick Reply: First 9 second 1/4 Mile Pass, 9.97 at 140 mph Edition 1 Coupe
