E-Class (W213) 2016 - 2023
W213 Mileage correction after retrofitting
Old 04-17-2019, 11:52 AM
SMark98's Avatar
E W213
Exclamation W213 Mileage correction after retrofitting
Hi,
I have a problem. I purchased a used widescreen and I replaced the audio 20 to widescreen with ntg 5.5.
So everything works fine but I have problem with milage. The display show this.: -------- .
I would like to ask how to add to the used display the original milage?
Thank you.
Mark
Old 04-17-2019, 02:46 PM
elnos's Avatar
W213 E43 Diamond White/ Designo Nut Brown
Following
Old 04-19-2019, 05:11 AM
Acho330's Avatar
w213 e220d
There is a workaround, send me a PM and I will send you a contact number. As I am aware of there is only one person who can resolve this issue.
Old 04-19-2019, 05:13 AM
Acho330's Avatar
w213 e220d
BTW the '--------' is because you got a used LCD. New ones don't have that issue.
Old 04-19-2019, 05:22 AM
SMark98's Avatar
E W213
Hi,
I know if I buy a new one its not have a same problem. But I currently have a used and I search a solution for my problem. I sended you a PM.
Old 04-19-2019, 05:26 AM
Acho330's Avatar
w213 e220d
Talking
Originally Posted by SMark98
Hi,
You got mail
Old 05-30-2020, 02:40 PM
Darius A's Avatar
2017 E300
W213 New Digital Cluster mileage problem
hi Acho330,
i purchased a brand new cluster to swap from analog. I am still running into the ——— mileage issue. Do you know a fix?
thanks
Old 11-24-2020, 01:20 AM
Junfei Zhang's Avatar
E300
I have same problem. I purchased a used widescreen and I replaced the audio 20 to widescreen with ntg 5.5.
So everything works fine but I have problem with milage. The display show this.: -------- . What is the PM that I should send? can you help me fix that issue?
thanks
J
Old 10-17-2021, 03:10 AM
godziejewski's Avatar
W213
w213 milage correction
Hello, i need to change milage on my w213 digital dash, probably smbd can help me
thx in advance
Old 10-03-2022, 07:27 PM
W213
let me know please how much you charge and what we have to do
Old 10-06-2022, 12:26 AM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
thx in advance
This sounds illegal. Especially in the US. I thought this forum doesn’t post clearly illegal information.
Waz123 (10-06-2022)
Old 12-15-2022, 02:03 AM
nycknth's Avatar
2017 e300
this needs to be coded. there is someone in nyc that can do this
Quick Reply: W213 Mileage correction after retrofitting
